I think I am going to go the washer route too. I am going to add my magnet on the clip. I had a magnet, but I accidentally mostly demagnetized it adding the heat shrink. I rushed it and got it too hot.
alienth
(alienth)
882
Can you tell me what changes you made to the source code to run an external diode? Which pin in MCU did you use for aux led?
BTW Great job!!
contactcr
(contactcr)
883
I’ll post the firmware changes but click on the aux boards link in the post for more info. There’s a few ways to do it
contactcr
(contactcr)
885
Here are the changes I made if you are familiar with editing and compiling the firmware. If not Lexel posted some .hex files with similar changes already made in his thread.
alienth
(alienth)
886
Thank you again for your help. Above the final effect :)
contactcr
(contactcr)
887
Nice, what did you use for your aux LEDs? Lexel’s board or a PCB with secondaries?
teacher
(teacher)
889
@ KB…
You owe me a keyboard. You did not post a ’DROOL WARNING’ wth your photos & I shorted my keyboard out. It was bad…. magic smoke & flames. .
Seriously… those look amazing!! .
xevious
(Gary)
891
Seriously impressive! Man, sure hope the FW3A evolves into a later version providing aux LED’s like this. I just don’t have the technical know-how to do it myself.
@ KawiBoy, you’re giving my eyes diabetes.
alienth
(alienth)
892
I did not use any additional board. I placed the additional diode centrally on the existing board and connected it to the driver.
I compiled the latest version (FW3A) of adruil with aux led support. Everything works very well :
pol77
(pol77)
893
Sorry if this has already been asked, but is there a guide with pics of the mod required and also a guide and firmware for flashing, hopefully including a good cable for the flashing?
f0xx
(f0xx)
894
Start here: [SALE] FW3A lighted TIR board multicolored with LVP, stabilized or High/low
The flashing process is pretty much the same as any other attiny85 based driver. Lexel has a bit of info and a precompiled .hex file in his thread where he is selling these boards.
You’ll need a USBasp, an SOIC8 clip and something to connect them (dupont wires are the usual recommendation). For instructions, there is a thread going up for the D4V2 and the instructions will be adaptable to the FW3A. The main differences between the lights are the method of connection (FW3A uses a generic clip and the D4V2 uses a special programming key), the chip being flashed (attiny85 instead of attiny1634), and the file to be flashed.
I think there is an old thread/post by Hoop on how to flash attiny based drivers as well. (they are all very similar)
contactcr
(contactcr)
895
You only need to flash if you want high/low/off. Lexel has a board with LVP built in you can wire up with no changes but you get 1 brightness level and always on.
teacher
(teacher)
896
Approximately how long before one of those boards drained a battery?
Is this correct…
A 0.3 mA board would drain a 3000mAh battery in approximately 10,000 hours??
A 0.5 mA board would last about 6,000 hours with the same battery & no LVP.
Have I figured that correctly??
contactcr
(contactcr)
897
Yes I believe so.
Just as a reference the D4v2 on high draws 3mA according to TK so 10x higher than some configs here. Them fancy bright RBG LEDs you pay a price for!
teacher
(teacher)
898
Thank you contactcr…… :+1:
BOO5TED
(BOO5TED)
899
So, deep carry pocket clips. Anyone make them?
