Fw3a
I think I have an FW3A copper flashlight and I can’t figure out how to get it out of lockout mode. If I press the button it just blinks. If I press and hold it just strobes. I appreciate any help. Thanks!!!
Four fast clicks should do it.
I’ve tried that multiple times. It’s till not working.
Or unscrew the head and reattach if that doesn’t work. Strobing shouldn’t happen when you hold the button down.
Worked!!! Thank you!!!
Theater did it!!! Thanks!!!
Glad that worked. Always make sure the tail is as tight as you can get it and then tighten the head. After that, you can check the driver retaining ring, switch retaining ring, etc. Should it give you trouble in the future. There is a lengthy thread here about the foibles of the FW3A, but they mostly work ok.
Kirk
Excellent!!! Thanks!!!
