The charger starts at 4 amps and slowly reduces as the batteries charge. The charge voltage is in the 13.something range. The way I determined which bad batteries to remove was by watching the amp meter on the charger as I removed each battery . The bad ones made the output amperage jump up when in the circuit. When only good ones remained , the current dropped and the voltage of the batteries all were 12.something volts. All the bad batteries were about 9 volts or less .
