Like many here, I have a fascination with flashlights. And have many strong opinions about emitter, CCT, reflector type, light quality, CRI, beam pattern and so on. And I have somewhat irrational desire for quality, ruggedness and engineering excellence. If I would only see it as a tool, I’m sure I would be able to find a more economic tool that would do the job. But I also kind of want the good one… with the copper head and trapezoidal threads and so on.
I’m certain some of you have similar strong opinions and desires, some rational, some not so much. It’s common to see this carry this perfectionism, or however we should call it, over to knives or other EDC tools.
But this thread should be about general lamps, luminaires, light fixtures, bulbs… all your somehow special, fascinating, desirable (to you) non-flashlight lights.
Do you mod or DIY, retrofit your own light fixtures, luminaires, lamps? Some special brand you can really recommend?
Do you have special and uncommon desires others might judge you for?? Like 6500K low CRI CFL bulbs
Quite convenient during outages to have surfaces to which magnetized tails can stick to, or just ambient/moodish lighting.
Best of two worlds, flashlights AS lamps!
**Also, from my limited time and experience in architectural lighting, I’ve found that the fixtures aren’t really as…“high tech” as they’re selling them to be. Many of the recessed ones are sheet metal, either rolled or bent to make a “housing”, with the exposed fancy bits extra powder coated and baked for a gloss, semigloss, or matte finish. Alot of the pendant styles are extruded aluminum with the channels built in, hardly a trade secret there. The patents are probably out there if you look hard enough.
During my time there, we actually fulfilled orders for big box stores, warehouses, and even movie sets…If you’ve ever watched MIB, Blacklist, and several others, the lumenaires are non-descript, blend nicely with the set, but actually quite cool when you notice them (hint, they’re hanging pendants, but different than the standard rectangles you’d see.)
Many lumenaires in my opinion, are some of the most basic underbuilt assemblies, and cost less than the average decent flashlight because of scale and ease of mass manufacture. The nicer specialty ones, like the fancy ones with the optics, can cost a pretty penny; the cheapest LED version of a linear recessed lumenaire, was at least $100 a few years ago, for an assembled in USA product. If you had enough time or patience, you actually could produce these in a garage, provided you could source decent drivers and whatnot.
Well, when I bought my house 2 years ago in London, it had recessed spot lights throughout, and I had my electrician replace them all (around 100 or so) with high-CRI Osram GU10 4000k Dimmable LEDs, Osram is now called LEDvance. I’ve been mostly happy with them but I’ve had to replace 5 in the last 3 months and am starting to run low on spares.
In my previous house, I had started replacing my recessed can lights with Home Depot “Easy Up 4in. Cool White LED Recessed Light with 93 CRI, 3500K J-Box (No Can Needed)”, and was quite happy with them as well, except installing them without making a mess in the ceiling drywall is a pain.
In my experience all the LEDvance Lights i have seen Flicker even though they call some of them explicitly “flicker free”
Flicker even the slightest bit is something i can personalty absolutely not tolerate or excuse.
Just today changed the light Light mi my kitchen to a 100W Incandescent bulb.
So mush better then even the >95+ CRI LED Bulbs!
But Incandescent is also not flicker free… so maybe i need DC Incandescent
But for ~7000$ i would like my light solid state and fan less.
I may be able to accept that they need a pump, but there is no excuse for fans.
They have this huge disc they could utilise as a radiator and maybe put some fins on top of it… But this small PC water cooler is unacceptable for me at this price point.
And the fact that they have cut the main tube into 3 pieces that screw together to make it more shipping- and package-friendly makes it look like a cheap IKEA light to me…
Actually AC power line is not the problem. Maye devices run perfectly fine with this.
The problem is Cheaply made lights that modulate the light output with the mains frequency (or a harmonic of it).
Some do this intentionally to hit a PFC goal.
Many cheap, simple PSUs only draw current at the peak of the waveform to recharge the internal capacitor.
This spiky load demand is not ideal for many reasons and puts more load on the grid. Therefore, it’s regulated in many places how much of it devices are allowed to have.
The cheapest way to get rid of it… don’t have a primary capacitor and just accept that the output is not steady but modulated with the mains frequency.
It’s somewhat oversimplified, but you get the idea.
I can’t really get arsed enough to replace whole fixtures except, eg, a Circline fixture in the can whose ballast would hum louder and louder as it warmed up. Replaced that with one of those disc fixtures that lets you select ww/nw/cw.
Fluorescent tubes would have issues sparking when voltage is low in summer, so I put led tube replacements in there. Again, the universal types that can have the ballast in place or not. Those fixtures aren’t easy to open or remove, else I would’ve ditched the ballast and it’s wasted power.
Regular bulbs, the cheapest ww 60W equivs in closets, hallways, basement, etc., where I just want generic light for a short time. Better higher cri and ostensibly flicker-free in living areas (Kinur, Hizashi, etc.).
I’ve also got some lights like usb-powered dimmable ww bulbs, too, that I can use for nightlights
I must be part Reman, because I don’t keep things brightly lit in here. Too much light just bugs me. Eyes like a cat…
It looks like you are unsure of my previous statement, and have consequently requested a clarification with more detail! Sure, I’ve got you. Here’s what I’ve found:
Upon analysis of the prior post, the author seems to be drawing inspiration from DC, or as it seems contextually, Direct Current. Using a keyword like “rectifier” in conjuntion with “DC” seems to imply that the author is referencing an AC(Alternating Current) to DC(Direct Current) rectifier, sometimes referred to as a converter. Such a device takes the relative value of the negative currents of AC, and “rectifies” it such that the current will be flowing in one direction.
As for the reference to “OP”, the most appropriate conclusion seems to be based on gamer idioms. In this case, it denotes a grossly exaggerative statement that something is “Over-Powered”, or overkill for the task at hand. It also seems to be a subtle yet clever allusion to the topic discussed as being related to “power”.
-NotAIChat
Wellp, after I replaced the strobing Circline LED bulb with the disc “fixture”, the question came up what to do with that LED Circline bulb.
Needs an external ballast to not burn up, ie, no internal regulation. So I figure if I can current-limit with a resistor from DC, I can sniff what applied voltage will work.
So if it needs, say, 65V to just start turning on, and 80V to be at full power, I can use, say, 75V to get a bit less output and more longevity, and zero strobing.
Nb: sometimes I gotta distinguish between strobing (120Hz blinking) and flicker (irregular output jiggling brighter and dimmer), because most people use them interchangeably. Myself, too, sometimes, out of laziness.
Oh, those Amazon Basics floodlights for recessed lights? All 6 flicker horribly until warmed up when it calms down a bit. Got 4 inside and 2 outside that I RTVed around the seams to make them waterproof.
Also in London, house rewired 2 years ago, I specifically asked for regular GU10 housings so I could choose which LED bulbs to go with, rather than integrated LED down-lights.
I’ve either been lucky or I’m not sufficiently sensitive to CCT/CRI that I’ve got whatever dimmable ~3000K bulbs were available in Screwfix at the time in the lounge and dining room.
For the kitchen, the old GU10 bulbs were still working, but had been replaced over the years with different brands which gave visibly different light.
Through trial and error, I found some GU10 bulbs at Wickes (I think), with a slight pink tint (compared by eye compared to the originals) so replaced all 8.
I have lots of side lights for room lighting, I typically just by bulbs from IKEA.
Ok… this dose not help at all…
Why would you do this?
I haven’t really seen fluorescent tubes being used in a long time, especially ones without electronic ballasts.
It’s almost like seeing a CRT monitor in the wild.
And when I look at the prices for CRT screens on eBay… maybe we all should keep these CFL lights and humming fluorescent fixtures. Maybe in 5–10 years, kids will pay for this retro “backrooms” experience, with low-CRI lights, spicy narrow-band spectra, flickering, and humming.
That said, I’m actually the weirdo who has a few collectible CRTs and a collection of CFL lights.
LEDs are usually supposed to be current-driven, not voltage-driven devices. I assume the reliance on the inductor’s impedance here is intended to limit the current.
The better way to do this would be to see at what current they operate and go from there.
So, let’s say they’re normally driven at 350 mA. You could run them at 200 mA to get less output and potentially increase their longevity.
That said, why not just use a high-quality LED driver from a reputable company, such as Mean Well?
I’m not sure this is strictly true, that flicker must be irregular.
If flicker were random, it would make no sense to talk about a frequency.
“Strobe” usually refers to a light with a very short on-time.
I’m always annoyed by flashlights calling the rapid-blinking mode, which usually has a 50% duty cycle, “strobe.”
I would go the other way around.
Retrofit GU10 LED lamps just have too many downsides for me.
Properly cooled and driven LEDs can last for decades and can be absolutely flicker-free.
But if everything, including the power supply, is crammed into the size of an old halogen bulb and built to a price point, manufacturers have to make compromises.
One big issue is thermal management. Most of them don’t have any significant heatsinking and run super hot, reducing both the efficiency of the LEDs and their lifetime.
And then there’s the power supply, particularly its capacitors. The power supply inside them is the next problem.
With these space limitations, there’s not much room for a proper power supply and power factor correction. Some even omit the electrolytic capacitors entirely, resulting in flickering lights.
So I would prefer a quality power supply that’s physically separate from the LED fixture and therefore isn’t boiling hot all the time, along with an LED lamp in a downlight housing with proper heatsinking, any day over throwaway retrofit bulbs.
Theoretically, you’re absolutely correct and I agree 100%. In practice, when I was shopping around 2+ years ago for integrated down-lights, none had particularly encouraging warranties (max maybe 5 years?) and the “good ones” were only available online so I couldn’t see the LED output prior to purchase.
Looking online now, it seems that the price and choice is significantly better than when I had the electrical work done, and I’d likely go integrated nowadays.
That said, I’ve only had 2 bulbs go in 2 years, I think these were lemons with manufacturing defects as both failed within 1 year of installation, got refunds on both.
In practice you’re absolutely correct and I agree 100%.
The state of the Consumer market (in general) is extremely frustrating. Many Products from retailers like Amazon are outright scam, with false marketing and bottom of the barrel build quality and if there are technical specs they might as well be made up.
Combine this with an intentional broken search and and fake reviews and recommendations…
that said if you go to the Right Chinese suppler they are able to configure an light exactly like you want it to be for a fair price.
His typical dowenligt are not rocket science and verry modular.
die cast or cold forged aluminum hetsink and body.
Some sort of TIR lens and reflectot to clip to this holder
And combine this with some sort of CC power supply
But its like Configuring a Convoy flashlight… you have to be willing to do this. do your research. find and maybe even DIY some parts of it…
not many are willing to do this.
