I have a folding knife that has a stainless steel handle (Ruike P135-SF). It is a beautiful knife. However, the scales get very slippery when any type of moisture gets on it.
I searched online for a product that I can put on the handles that would be transparent, so I don’t ruin the beauty of the knife. I did not find anything, but that is not to say that no such product exists. Maybe there is a liquid adhesive that dries and leaves a non-slip grip. Maybe there is a transparent adhesive tape that provides a grip surface.
Safeway Traction Tapes are perfect for precisely this type of application. In fact, as far as I can tell, this is the bulk version of specialty, grip tape products that are custom die-cut primarily for adding grip to firearms & cell phones like Talon Grips, GT-5000, & Gear Gripz, among many products for various applications, but at significantly higher cost versus these bulk rolls. Safeway does offer small sheets, but they’re just so much more expensive than even the smaller rolls of tape. Anyway, Safeway’s main website lists many products which I find cumbersome to navigate, so the following link goes directly to their “rubberized” versions of traction tapes available in black, white, gray, and clear and in a variety of widths & lengths.
Although even the smallest, least expensive rolls start above $10(USD), I guarantee you’ll find so many things you can use these tapes for adding grip or traction, you’ll likely end up buying more before long. Plus it’s amazingly durable, including under foot traffic.
I use both black & clear on knives and lights,and like you, I wanted a solution that wouldn’t obscure a pattern or the general look of knives in particular. Although the clear tape works fairly well for that purpose, the mottled appearance of the rubber that provides the grip, isn’t quite see-through. However, I personally find that the added grip easily offsets any relative loss in the appearance of the otherwise slippery scales. When I get a chance, I’ll see if I can upload some photos of those items where I added this tape to improve the grip. I hope this idea proves helpful to you and others. Good luck!
