ghetto 4 bay <$3
4p 18650 at 1a.
assembled with bubblegum & baling wire ca glue and zip kicker.
dont reverse any cells or the thin wires become fuses(intentional).
also kills tp4056.
i coated the board with ca to protect it.
the holder is an ebay cheapie from china that i prefer over the more expensive mpd at digikey.
dont have to bend the contacts to prevent wrapper snagging.
not bad for $1.35 each SHIPPED FROM CHINA.
i busted the partitions out to allow 26650 to fit too.
Cool idea. Where did you get your “good” TP4056 from? i’m seeing many of them now from cheap sellers with fake chips on them.
Well I recently bought a bunch from a US seller; I was unaware there were fakes. How am I supposed to know if they’re good?
There is a topic mentioning the fake issue here on BLF somewhere. I think the fake TP chips had different or no numbers.
I believe most chips from ebay are fake… but they work sort of ok with simulated CC/CV. I made a dual bay version but without a good 18650 holder it is not very convenient.
the ones i got came from icstation.
they seem to work fine and have accurate cv.
only issue was a few had the usb crooked.i just heat it with the air pen and nudge it into place.
Do you have a link for the holders?
I had those with protection and those with springs, but I never had one of these.
1 2 3 and 4 cell
Thanks for the link. This looks better than the spring type that are impossible to remove the batteries from….
I hear what you say about being impossible to remove. What I've done to fix this problem is drilled a hole the diameter of a pencil about 20mm in from the negative end of each bay and push the batteries out with the eraser end of a pencil.
A bit dangerous this way as the individual slots are not isolated….putting batteries at different charge levels into a circuit could cause issues as the higher charge batteries will push current into the lower charged batteries…too great a difference and the current flow could get dangerous.
I did the same thing…but was educated on the dangers of mix and match batteries in a parallel charger like that
Be safe…but still a very cool idea
Boards are cheap enough…get multiple single slotters and charge boards…safer that way
yes the non techie folks can get into a bunch of trouble fast with this.as for differing charge states i tried mixing dead and full cells and the high current leveled out fast.
measured 5a and that settled down to 2a in 30 sec.
nothing i would worry about.any reversed cell in the holder is trouble.that where the thin fuse wires come in.would suck to have a hard short where nothing gives!
