Good Budget luxmeter?
Looking for some info on ways to measure the output of my lights.
I know very little about the tools used for these measurement, but would like to have a way to compare various lights.
General ideas of what I am after……….
If possible a way to measure total lumen output, as well as lux.
1)ready to use, with the exception of “assembly required”, thats fine. I am not looking for another project.
2)Don’t have to be crazy accurate, as long as it will show if improvement has been made or not (say +/- 5%). Not real worried about “calibrating” to match this or that persons ##s. Again, just looking for relative comparison between lights in my possession at the time.
3)cost effective.
Not the same as cheap. I want something that works, if its $100 thats fine, but if I can do the same with a $50 tool that leaves $50 for more flashlight parts. :wink:
My budget………that depends on how soon I want it, and what you guys recommend, but for the point of suggestions lets say UNDER $200 total.
If its that high, I’ll have to save up for a couple weeks.
Thanks,
Jim
To measure lumens you need an enclosed environment.
The best way to do this is with an Integrating Sphere… basically a sphere with an opening for the light to shine inside, and another opening for the sensor on a luxmeter. A baffle separates the two so the meter only sees indirect reflected light from the flashlight.
Buying an integrating sphere is very expensive, but it is possible to make one cheaply out of paper mache.
If you don’t want to make or buy an integrating sphere you can try the “integrating bathroom” approach. Exactly what it sounds like. All you need is a luxmeter and a bathroom.
Ok, so lets start with a luxmeter recommendation, and I’ll look into building a simple and quick I.S.
If there is something I can get done in an hour or so, I may give it a go. Just don’t have as much time as I’d like anymore.
RMM doesn’t list a luxmeter (or an I.S.) that I can find so I guess I’ll have to find them elsewhere. I guess its a good thing I haven’t had my paychecks sent directly to him just yet. :stuck_out_tongue: I definitely spend way too much $$$ there as it is.
Amazon shows meters from >$20 to several hundred.
So, any recommendations for a decent luxmeter @ $100 or less, and if possible reliable source here in the U.S.?
Thanks,
Jim
