Hey all, I bought parts for a couple Triple Nichia builds. One is going into a Sinner 18350 ti host. Any suggestions for another? I’d love to try a blue Convoy S2+ but the pill doesn’t seem ideal for a triple. Any suggestions or perhaps mods to the convoy S2+ or S3 pills etc?
eagle eye x6 with the heatsink im selling ?
I second that
RMM sells a spacer for the S2 to make a triple. That’s what I’ll be using for my triple nichia
How about the S2+ or S3? Any cool colour options for the S2?
The Eagle eye is faifly big though isn’t it?
I was hoping for something smaller.
An hour with a handfile is all that’s needed to convert an S2+ pill for use with a triple. No spacer needed. I did that with my Convoy S2+ mini.
Oh, so just file off the edges, maybe drill a hole in the middle? Could work. I’ve been eyeing the S2+ in blue with (hopefully) a steel switch.
The mini is cool but I’m not a fan of the look.
i think its perfect and great heatsinking, it has about the same battery tube but with a larger head and have more driver selection ?
1. File off the top of the LED platform. The stock platform has ridges at the sides to center a 16mm star. Filing it flat lets it fit a 20mm triple star.
2. File off some of the pill threads at the top of the pill. The S2+ head isn’t threaded all the way to the end. Because a triple star sits closer to the front of the light than the stock star, you’ll need to take off some of the threads to allow the pill to ride higher in the head.
3. Drill a hole in the center of the pill for the driver wires.
If you want to make your mini a powerhouse like I did with mine, you can also file the bottom of the pill to make the entire pill shorter. In mine I used a combination of filing and grinding with a cylindrical grinding drill bit. This allowed my S2+ 18350 mini to fit an 18500 cell without any changes to the exterior of the light.
Regarding the S2+ mini’s styling? … yeah it is rather plain. Can’t help you there though.
Firelight2 i think you should make a new topic with photos of this little monster you build.
Yes, I’d like to see your build too!
Convoy S2 uses a spacer sold by RMM here (mountain electronics) in both aluminum and copper that will let the triple work just fine.
The Convoy S2+ doesn’t need the spacer as the reflector is a short design
These make AWESOME triple hosts!!! A tiny little pocket carryable barn burner especially if using a direct drive MOSFET driver and a good high current battery…just make sure you don’t run it on high for too long…they will get hot ![]()
I had built some S2 triples with Mtn aluminum spacers—I purchased a few S2 mini—the standard S2 pill with spacer threaded right into the mini head combined with the mini tail cap made for a 18650 length S2 the length of a S6 and nicer looking than a standard S2
You still need a spacer, just not as long as an S2 spacer.
Are there any other suggestions for relatively affordable and compact, side switch triple hosts for EDC besides the smaller MecArmy PT series of lights?
Jaxman E2L host?
I can confirm that the E2L host has no side switch.
Great host, I am going to order one from RMM when I figure out the driver.
The difficult task is finding a suitable host with a ‘side switch’.
Maglite C/D with an SRK reflector?
Eagle eye X5 is an S2-sized light with a side switch. Not sure if the triple mod in this light is simple, but it looks do-able.
