It’s been ~11 weeks and by now this light has seen quite a bit of use. I’ve worn it on night rides on several occasions, which usually last 1-2 hours, during which the light is constantly on mid mode, and during which the tilt is adjusted at least a half dozen times. Tonight, I ran it on high for an entire hour while I vacuumed the pool in the dark (don’t ask) and while the bezel was warm-hot to the touch, heat was not an issue. I use AW IMR16850 cells in it, which are fully charged after use and stored in it until next time. It’s the best headlamp I’ve owned so far.
I noticed that it's now only $19.99, so I ordered another. :)
I’m loving my headlamp. I have been using it as a backup for frog gigging. It’s awesome on high.
so it uses 2x18650’s? shouldnt this light be super bright then for a headlamp? most only uses aa, aaa, or 1x18650.
do any of you guys that have this light, also have the uf h6 head lamp?
i just ordered the uf h6 because i wanted the brightest headlamp $40 could get me, and i got many recommendations for the uf h6, now this one is tempting.
It uses 2 x 18650 in parallel. It's actually driven quite low (biased toward long runtimes) and thus not any brighter than others.
I have both and like them equally, but for different reasons: UF-H6 is small & easy to grab when needed, also for smaller tasks. It also has better modes and UI. OTOH, this headlamp has good runtime even on high (driven lower + 2 x 18650), so it's good for longer hikes etc.
I'll see if I have time for making a beamshot comparison tonight. If not, I'll do it during this weekend.
I would say it is very close to 400 lumens.
Looks to be the same one I bought a few weeks ago, now mounted on a safety helmet, good throw on high, but the low is good enough for most purposes.
Do you think this light can accept a E1320 or Dr. Jones Luxdrv ramping driver? I don’t have a dedicated headlamp and this might just fit the bill. Do you have pics of the internals?
Thanks!
yes beam shots would be great thanks
I put a picture back up on post #6.
