Finally got my TO46R, TO10R, and spare emitter board (nearly 4 weeks of wait time).
For some reason I thought the TO10R was able to run 18350’s but found out it would only fit a 16340…Bummer…. gotta read more carefully next time. (May bore the tube out to fit a 18350 in the future…have 2 18350’s sitting idle… will probably throw them into the Manker E14 with 18350 tube. )
What I observed after playing with the lights (tried some lego part swapping) some more:
46r: Head on 46r is “glued” on to battery tube. Long press of power button (while light is off) turns on turbo mode.
10r: Tail cap is “glued” on to battery tube. Long press of power button (while light is off) activates strobe (but momentary only and must be held down to keep strobe).
I’m assuming Wuben doesn’t want us lego-ing these lights…
Will go read the manuals to see if I can change them.
One minor annoyance is the charging port flap/cover tends to get in the way of the micro-USB plug. This may deteriorate the cover and compromise the water ingress protection if recharging the light often via the port.
