The mods:
the short story:
xm-lt6 from trustfire Z6, 2.8a 105c driver set to h-m-l, aluminum vga heatsink
the full story:
stock driver was rivet/soldered THROUGH the base of the reflector to the emitter?!
After ripping them apart and bending up the back of the reflector, I cut off the base, then filed it exactly to the start of the reflecting surface.
Next, I wanted to be sure I could tilt the headlamp farther forward than shown in the picture with it sitting on a hat above. So, I heated the part of the housing that touched the hinged with a hot air attachment on a torch, then pushed the housing forward (I forgot to get a pick of that...basically it just put a nice even dent in the housing that you can sort of see in the second pic below).
The heatsink was next.
In order to be able to retain full swivel range, and get the heatsink to the emitter, I cut the back of the housing off and filed it (reasonably lol) flat.
After checking fit/focus and marking emitter placement, I drilled and tapped the heatsink for emitter retaining screws.
Then I hot glued the heatsink to the housing, turned it over, put a big hunk of play-doh in the middle where the emitter would go, and in the hole where the wires enter, and then slathered jb weld in there. You can smooth jb weld w/ water soaked fingers, almost like it is clay.
About 3 hours in the toaster, wrapped in aluminum foil, on very low, and it was set, so I ripped the hot glue off and cleaned out the play-doh in the sink.
Next was the circuit. I potted (one side of) a 105c w/ devcon 2 ton and alumina, jumpered it to h-m-l, replaced the stock switch w/ the one that comes in most xxxfires, connected everything w/ twists to test current, soldered it all together, insulated w/ shrink and plasti-dip, and hot glued the stuff back in.
Stock battery did 2A on high, Panasonic cgr18650ch 2.6A (should have used better wire...but it is on 'the slow boat' lol).
That's it for now.
I won't be putting this thing near my face w/ that battery. When I get a dedicated IMR, I'll install that. I might drill new holes for battery cover retaining screws, and use wing nuts on the front side, or I might just screw it back together, cut the connector off the stock charger and wire it to a dummy battery for charging w/o removing cover.
pics! sorry my beamshots suck. I did finally get a new camera, but I don't know how to take beamshot pics yet (they're worse than these cell phone pics!).
this is like 2 feet from the wall and the camera is about 5 feet - massive spill
citipower X5 2.4A, same position/distance
citipower x5 - gtl xml
same w/ cam brightness turned down - no donut past 4 feet
Despite 'appearing' dim in these shots, the spill is PLENTY bright to be useful, and the throw is so far it is ridiculous - great for a bike helmet, snowmobiling, etc
cost - host $16.99, emitter ~$9, driver $5, heatsink was scavenged, still need a safe battery. not cheap, but budget, imho.
I'm about to do some heat testing, but so far in playing around w/ it, heat isn't an issue at all.
