It may also be worth filing down the edges of the driver a little, to make it easier to put back in. Sometimes the glue sticks out and makes it difficult to put back in as deep as where it originally was. I usually do this with a cheap diamond file, gently going around the edges, but not enough to remove a significant amount of material.
Also, once the glue is broken, it’s a good idea to keep the body tube tightened and only unscrew the tailcap. The body tube is effectively a giant retaining ring for the driver.
