How do you handle parts safely ie lenses and other delicaite parts
I wear gloves when working/soldering on lights. After removing the lens or reflector I put them in a zip lock bag so all the dust and dirt won’t get onto them.
Nothing special. Lenses, I’ll handle freely, but then use detergent to clean both sides, dry as lint-free as I can (maybe a blast of “canned air” for stragglers), and then reassemble. Last time I did that was to slap on some diffusion film.
Only things I handle “specially” would be reflectors, ’cause one oopsie and it’s pretty much ruined.
One trick I learned from Matt (AS flashlights) is, in the worst case event you do get debris in a reflector always, ALWAYS blow canned air up from the LED opening, NEVER EVER down in from the top!
Also you need to make sure you’re handling TIR optics with the same precautions as reflectors, never touch the back of the cone or anywhere, I only handle them by the outside edge or the legs.
1. Wear gloves.
2. Vacuum the place before working.
3. Make a solution of sodium carbonate to remove fingerprints on glasses and reflectors.
DO NOT MAKE A LYE/SODIUM HYDROXIDE SOLUTION.
4. Wash your hands before.
5. Get a small fan to blow dust off of the work piece.
Thanks for the info and yes found that out about Tir optics didnt realise they are so delicate. They scratche so easy looks a mess but doesnt seem to effect beam to much.
Of course they can easily be scratched. They are made of plastic.
However, reflectors are even worse.
Yes a lot things are but they are super soft
I can only hope everyone in China who handles components is using a properly grounded antistatic mat.
But I wouldn’t bet on it.
Point is not to add to any existing damage by mishandling the driver components at home, since ESD isn’t one single lightning strike, rather it’s slow degradation over time taking components out of spec, damage that adds up to inconsistent behavior.
Competent parts providers ship drivers and components in pinkish antistatic plastic. Most of our commonly relied on sources in China ship in plain transparent plastic bags that add to static electricity risk.
[emphasis added]
