I’m thinking that the driver, plastic disc, and spring are all together, and that this is designed so that the plastic disc is pressed into the pill and holds all 3 things in the pill? In other words, what holds the driver in the pill is the plastic disc?
For the manufacturer, they just have to push the whole assembly into the pill, and they’re done.
And, for repair, they’d have to destroy the plastic disc to get the driver out and put on a new disc.
Is that possible?
I’ve been reading comments that Crelant lights are designed for lower cost manufacturing (but not necessarily lower cost maintenance/repair), so am wondering if it’s possible that the above is the case?
If it is, I’d have to break the disc to get to the driver?
EDIT: I may have to try that, as since the light isn’t working, that may be the only choice I have?
EDIT 2: I got the disc out! As I was surmising, it was just press fit into the pill. It’s not just a flat disc, but more like a “cap” with a hole in the middle for the spring to poke through. I had to enlarge the two holes I made earlier, and then used a pair of hemostats to grab the two holes and just pulled, and the disc and spring came out.
And, the spring is NOT attached to the driver. Rather, the driver has a plated through- hole right in the center, and the spring is suppose to go into that hole, to provide the positive contact from the battery. I have no idea how they actually make sure that the spring goes into that hole, because they’d have to basically do it “in the blind”.
The driver is not attached to the pill, except for one spot, where it appears they soldered from the negative ring on the driver to the side of the pill, I think to provide the negative input to the driver.
I have no idea how they did that either, because the driver is pretty deep in the pill, which is aluminum. I’d not want to be the one who was doing that, as I’ve had a heck of a time soldering drivers to aluminum pills :(…
Once I had the disc out, I took one end of a pair of tweezers and shoved it through one of the holes on the emitter side (BTW, the emitter is loose. There’s some white stuff under it, so they may’ve just put some thermal grease under it).
Anyway, I haven’t tested yet, but I think everything looks intact, so I’m guessing that the reason the light stopped working is that when I had it in a vise, it must’ve broken the driver to pill connection.
I’ll post some pics in a bit, so that if anyone tries this in the future, it might help them…
