Have ordered one, would like to see lumens and throw charts
Tested? Sorry, I’ve been too busy looking at it’s lovely rosy tint. It’s not going to win any awards for throw or lumens, but what it does do, is make illuminated things look good!
Sure I understand that and that’s why I ordered one, just curious about output levels compared to my other light.
I have a couple of S2+ with 219B for 2 yrs now but I never tested it.
All I can say is use a stock AR lens with sw45k if you don't want it to be that pink.
On all other of my S2+ i have removed the stock AR lens and installed a clear one.
Convoy's AR lenses are one of the worst in the industry, raising BBL drasticaly.
How difficult is it to remove the lens and fit a new one? Where would I get the other lens from?
So you never seen any S2+ videos?
It has a pill. U srew pill and lens will fall out…
Do some research or even worse sacrifice 15$ and buy one…
I already said I’ve ordered one…
Great, now do some research and watch Convoy mod videos.
Not to derail OP’s question (I don’t have measuring equipment), but I’ve noticed mine has an annoying dark spot in the center of the beam (maybe hard to capture in a picture). Is that a focus issue? Does the pill have to be tightened?? As well, this is my first S2 type light, and have never disassembled one. I’m seeing the cutout in the pill on one side is filled with solder. Thinking it’s gonna make it difficult to unscrew if I decide to fiddle with optics.
I had mine outside last night, and I would say the beam gives up after 50-60 meters or so. More floody than throwy, even with SMO reflector. I do like the tint though.
where do i get the non-AR lens for S2+? It seems whereever I look, the “in” thing is AR lens.
Can you scrub the AR off with baking soda?
You can do it, use pointy tweezers or some nose pliers (eventually thinner than usual), stick them in those 2 grooves near the solder and you’ll be able to do it withour de-soldering, etc. Rotate clockwise to unscrew and anti-clockwise to screw in back again.
As for the spot in the beam, are you using Smooth reflector? Is the pill tight enough?
If Simon doesn’t have them (send him message here on BLF or through the AliExpress app/site), you can check some stores in AliExpress. Normally Simon’s lenses are stronger than the other stores, but they’re out there.
Check Kaidomain as well!
I have also observed the donut hole/dark spot in center effect w/both the 219B and 219C LEDs in several different lights. For whatever reason they seem not to like shallow reflectors. I also had this problem in my D4v2 w/219C 4000K with the clear optic. You may try tightening or maybe even loosening the pill, you just have to experiment, as my understanding is the effect is caused by the fitment and height of the LED within the reflector. Other fixes might include sanding the centering ring or adding more height with kapton type tape, again just altering the interplay of reflector and LED.
Unfortunately I have never been able to resolve the problem with those methods, I smoothed the beam out with DC fix over the lens, or in the case of the D4v2 I switched to the lightly frosted optic.
Where the heck is location “S”. ?
You can try to tighten the pill, but it shouldn’t impact the focus since the LED is probably already tight against the reflector. An imperfect beam is a side effect of a SMO reflector.
In order to help smooth out the beam, you should start by installing an OP reflector. You will get less throw, but it does a great job at removing a lot of artifacts. That should remove the dark spot you are seeing. I have a 3000K 219B in an S2+ shorty with an OP reflector and the beam is wonderful.
You should be able to remove the pill. The driver is solder to the pill, but it doesn’t look like it’s soldered to the head.
Or just stick in the 20mm TIR lens of your choice, instead of reflector + glass.
You’ll thank me later.
Ready to throw a TIR party ![]()
So, did those TIRs do well? What did you test and were they the TIRs from the aliexpress convoy store?
I’m dying to know how those optics worked out. I just ordered my first Convoy, an S2+ with a 3500K Nichia and will probably end up replacing the smooth reflector with an optic.
