has anyone used the new 4.35 volt Panasonic 18650 protected 3400 MaH batteries?
Hello all ! I was wondering if anyone has used the new 4.35 volt batteries and if they offer any advantage's. Over the standard 4.2 volters ? I was planning on running them in a modded small ZY-TO8 modded to a series powered MT-G2 that Relic38 sent me.I understand ill need aanother charger because my Nitcore I2v2 only goes up to 4.2 volts if I am lucky so anyone have any knowledge of them please feel free to chime in.
Panasonic?
Link to batteries?
If you are talking NCR18650B’s, they are 3400 mah 4.2 volt Panasonic batteries.
Let me look up sku#I don't really know how to paste and copy on my phonebut no they are 4.35 volt s
EDIT:Fasstech sku:1341105 @ 16.98 a pair
These cells: Fasttech Panasonic 4.35v
Are miss labelled. They are 4.2 volt.
+1
Charging to 4.35v for Pannys, please don’t.
I believe 4.35v rated 18650s available now are Samsung ICR18650-30Aor30B, LG ICR18650D1 & Sanyo UR18650ZTA
Anyway, you still can charge the above 4.35v rated batteries with standard Li-ion charger, it will not get full capacity but you get longer cell life.
Those are the ones . It says on page you need the 4.35 volt charger to fully charge it.
FT yet to correct the spec.
Okay thank you for giving me a heads up
The picture with the batt hooked up to the charger/voltage tester shows the batt does infact charge to a maximum of 4.35v, so the specs are right. It might mean though that the cell will have a possible half life if charged that high every time.
The specifications are still wrong, but that does not prevent people from overcharging the battery.
I have the Pink LGs that are rated for 4.35V and according to HKJs tests they are still outperforming most if all batteries at high amps even charged at 4.2Volts. I am using them in my Black Shadow Terminator.
I use a digital charger that allows up to 4.3V termination voltage to charge them. I never max charge my batteries anyway and I prefer stopping just a tad below 4.2V (4.16).
