Does anyone now where to get a holster that fits HD2010, Y3, T08 ?
I found one post on BLF but it seems to the item is no longer available
Would be good to have an additional battery pocket as well but if not, just a holster would be fine.
The one used for the XinTD X3 should work. It's a tight fit for the X3, but I haven't tried it with the HD2010 yet.
http://intl-outdoor.com/xintd-x3-xml2-3aa-flashlight-p-739.html
I don't see the holster sold separately. You might want to send Hank and email.
For HD2010 I use this: http://www.fasttech.com/p/1330400
+1 Good fit.
Thanks, this one looks good. Does the belt strap have velcro or is is just a loop, I can’t tell from the pics on Fasttech?
Both, a fixed loop and a velcro strip on top of that.
A HD2010 hangs out about 5-6mm through the bottom hole.
Fantastic !!! Thank you. I might get a couple ![]()
I got a few of those Niwalker holsters - they fit quite a few lights, including ones that are bigger than a C8, smaller than a HD2010. The Yezl Y3 is another light that fits it well.
I use the Niwalker from FT fit’s perfect
I don't have a Keygos, so I'll defer to others.
Will the 57mm holster for the HD2010 also fit a Keygos KE-5, or would I need to buy another holster??
I've used these for C8 size lights: http://intl-outdoor.com/c8-flashlight-holster-p-258.html and I believe the KE-5 is C8 size -- I'd check for sure...
