I have a co-worker who purchased the 3x XM-L version of the HD-2010 from eBay, and it has since stopped working. It has the cheap Fry-Ray style triple drop-in so I am speculating that the driver has fried. Is anyone aware of a replacement driver for this model flashlight? The light uses a single 26650 cell and the triple drivers I have seen require a two-cell configuration...
Scaru, why do you expect all of the LEDs to have failed? How hot does it actually get then? I’d didn’t realise it was driven that hard?
I’d of thought a single cell, multi-emitter light to have used a parallel setup?
The problem is the heat build up. There is literally no contact in between the pill and the body. So if it was driven at 1 amp per LED that is 9 watts of heat trapped by the LED. I used to have one and I killed the LEDs. While using it the light became really blue and then there was a puff of smoke and itstopped working.
The drop-in used in the style of host is a really poor design with less metal/metal contact than a P60 host has... The reflector/pill assembly falls out when you remove the bezel ring with little to no thermal path between the assembly and the body of the light.
