heat and leds
Came across this youtube video on philips led light globes made for the Dubai market. Apparently they are under powering leds - load is spread out over more leds, compared to the led globes that are available to the rest of us. They end up with a brighter bulb, and because of the lower heat, a truly long life. Apparently applying more power to the leds results in diminishing returns - more heat with not much more light.
I was wondering if this is similar for the emitters in our flashlights? For example, I have a sofirn C8L, and there doesn’t appear to be much difference between high and turbo. High is approx. 1100 lumens and 2.88 amps; turbo is 2450 lumens and 7.45 amps. Turbo definitely seems like greater diminishing returns.
I hope I have put this post in the correct category.
Apples and Oranges. Heat reduces efficiency on one hand, and decreasing perception of differences at higher intensities on the other (s. Weber-Fechner law).
Overpowered LEDs are less efficient. That’s obviously visible in the datasheets as well.
If you need a more scientific explanation, find literature.
The way our eyes respond to light is not linear, with 2x the lumens you will not see it as 2x as bright. you need at least 3x the lumens to see2x as bright. 20-40% increase in brightness will not be really noticeable, 40% more current however will make noticeable increase in heat production, as well as heat load on the led, which affects its lifespan, i think due to naturally higher temps in Dubai manufacturers adjust how they make bulbs for that market.
