heatsinks for charging modules
What’s that black substance on top of the circuits? grease?
http://www.ebay.com/itm/3-35V-to-1-2-30V-DC-Converter-Circuit-Buck-Boost-Solar-Wind-Voltage-Regulator-/370884975783?pt=LH_DefaultDomain_0&hash=item565a779ca7
I’m looking for different ways to add heat sinks to those charging modules from ebay
The black stuff is potting compound, it's like an epoxy. That particular version is meant for through-hole soldering to a PCB, hence the four pins sticking up (down) at the corners. If you want to add your own heatsink, or if you aren't planning to use it attached to a PCB, start with the bare version: http://www.ebay.com/itm/370884960806 or pick one of the 800 similar but slightly different boards that do the same thing (search that seller's store for 'converter').
Thanks and I wish I could’ve picked one up that already had everything in it. It’s for this board though
http://www.ebay.com/itm/LM2596-LM2577-Automatic-buck-boost-With-charging-Constant-current-Voltage-/150997811347?pt=LH_DefaultDomain_0&hash=item23282bc093
I’m mostly looking to attach a heatsink to the backside of the board. Also seen these heatsinks which look like just the thing, though I doubt that the thermal pads are any good.
