Hello BLF Members,
After many times test and improvement, finnaly, the Helius Omega VI OLED display screen flashlight with wireless quick charge is come NOW.
Sorry for beling a long time for shipment. Because this is a new flashlight contains much more 2 technology than normal flashlight,so we need much time for developing, testing and and improving before shipment.
The purpose that we open this thread is to looking for the reviewers and any your comments on this flashlight.
Features:
◎ Adopted advanced intelligent wireless charging technology
◎ OLED display screen gives overview for operating status(modes,brightness,voltage and battery capacity)
◎ Dual dimming for convenient and easy operation
◎ Magnetic control system, slightly twist the rotatable ring to select modes
◎Toughened ultra-clear glass lens with double-sided AR coating
◎ Aircraft-grade aluminum with premium type Ⅲ hard anodized anti-abrasive finish
◎ Compact size for easy carrying and using
◎ Circuit with overcharge protection
◎ Reverse Polarity Protection
◎ Tail stand and can be used as a candle
Specification:
◎ Led: CREE XHP35 HI LED
◎ Battery: 2*18650 batteries
◎ High-performance metal smooth reflector, double-sided AR coated lens
◎ Output & Runtime:
Mode |
High |
Middle |
Low |
Strobe |
Output |
1500LM/800LM |
500LM |
35LM |
1500LM/9HZ |
Runtime |
1.5Mins/1.5Hrs |
4.5Hrs |
30Hrs |
◎ Working voltage range: 6 – 8.4V
◎ Material: aircraft-grade aluminum with premium type Ⅲ hard anodized anti-abrasive finish
◎ Weight: 228.5g (excluding the battery)
◎ Dimension: 158mm (L)*45mm (D)
◎ Beam Distance: 412M
◎ Peak Beam Intensity: 42500cd
◎ Waterproof to IPX-7 standard (underwater up to 1M)
◎ Impact Resistance: 1M
◎ Charging time:3.5H (Tested by Helius 2600 mAh 18650 batteries)
Charge Base parameters:
◎ Input:12V/2A
◎Output: 8.5V/1A
◎Work Temperature: 0-45 ℃
◎Transmission distance: ≦10mm
◎Color: Black
◎Material: Aluminum alloy
◎Plug the adapter into the DC port, the power indicator turns green
◎Recharging Indicator lamp
When being charge, the light is blue. When charging is complete, the light turns off.
More details, please kindly visit our website www.heliusight.com
