Helllloooo Opinions needed... quickly:)
Hello to everyone,
New guy here and would like to get some feedback from those in the know.
I wanted a tactical weapon light to mount on a Sig556.
normally I research things before I make a purchase but last night could not sleep and ordered a light and offset picatinny rail mount.
I own a surefire tactical light mounted to a Colt AR-15 and love it but just did nt want to spend that much again.
So what I got was.
EagleTac - EagleTac T20C2 MKII XM-L U2 *750 Lumen $90.00
also bought a pressure switch for it, but after reading the reviews on it it seems to be very confusing as how the controls work.
http://www.eagletac-usa.com/products/product.aspx?pid=1-3-6981
Not familiar with these and would like anyone who may have one or knows about them to give some input as to is it a decent light ?
thanks
PS: the reason I added quickly in title is because I can cancell this order before it ships. and order something else.
I have the EagleTac C20 MKll XML-T6.
It is a very good "ALL ROUND" light. Decent throw with some flood, Superior build, threads, knurling, size and weight.
Never used it on a mount, always coat pocket carry or holster.
And WELCOME to the forum rpg
I personally went with a Solarforce L2P on my shotgun. Pair that with a XM-L drop-in and it's less than 1/2 the price of the Eagletac. Solarforce sells pressure switches as well, in fact I have one I could sell you for cheap.
What kind of modes are you looking for? Single mode? Or do you want a strobe and different output levels?
Wanted High, Low, Strobe or at least one setting and strobe.
will look at the Solarforce L2P
The problem with the off-the-shelf drop-in modules out there, they won't have high-low-strobe. Usually only H-M-L or H-M-L-Strobe-SOS. Plus, you won't have the function of being able to twist the head to switch modes, only cycling with the rear switch.
So in other words, now that I think of it, the EagleTac isn't a bad way to go. There are a TON of options out there though, some probably being cheaper with the same functionality.
you better cancel
not because that isn’t a good light
but because you came to the right place and you’ll definitely be sure about your purchase after some time here, and you’ll probably spend less money
welcome :slight_smile:
Thanks for replying :slight_smile:
lol… I do wish I had known about this site before I ordered .
I ’ve been reading the posts here for over an hour and have already learned tons more about these little gems than I did.
Unfortunately I tried to cancell but the light has already shipped.
I’ve read some reviews and such and think I will be ok with it. if it does’nt work out for intended use I will use it somewhere else.
I probally did overpay but I will chalk it up to lesson learned.
thanks
Trust me, any amount you may have overpaid will pale in comparison to the amount of money you will soon spend on dozens of "budget" lights ;)
Welcome to BLF ! :party:
I think the light you just bought is fine and you will like it for sure.
Welcome to the forum. There are definitely people here who can help you.
I have the Eagletac with a different led and if I remember correctly, the mode is set by twisting the head and then turns on and off by the tail switch or pressure switch. It automatically come on in the mode you have set, this is what you want in a tactical light, you don’t want to have to cycle through the modes in an emergency situation. On most of the budget lights you have to cycle through the modes, even if they have memory and remember the last setting you used, this is not the type of light you want to fiddle with in an emergency.
Thank you I am learning this already
After reading about this I agree with you thank you for the reply
I am thinking you are right about that . I already ordered two key chain torches I found out about here, one for my wifes car with hopes of she will understand our need for all of these “unnecassary purchases” :wink:
sorry my post are probally confusing here . trying to reply to everyone but I am about computer illiterate :nerd_face:
I’ll second the SolarForce suggestion. Look at the L2P or L2T. Both are very well made and will take a lot of abuse. Check w/ some of the “custom” P-60 drop-in makers, they can make a nice dependable drop-in w/ exactly the configuration you want. I recall one maker lists a 3 mode High-Low-Strobe using a Cree XP-G emitter.
Ok Thanks for everyones replies, the Eagle T20C2 MKII XM-L U2 750 Lumen arrived and I have to say I freekin love it.
thanks everyone.
Thanks for stopping by, rpg!
