Hello Everyone
Hi, I'm Joerg from Germany and I've been reading this forum since quite a while ago. Thanks to all of you I'm totally addicted to flashlights now;-)
It all started with a Jetbeam Jet III Pro ST BVC some years ago. Since then, I got a Tank007 E09 and E19, Lumintop Tool, Ultratac K18, Convoy S2+, M1, 2x C8, BLF Kronos X5 and some Small Sun ZY-R804. I got the Convoys in parts and built them myself using standard Nanjg 105c drivers. In search for more lumens I then started modding some of these lights: One of the C8s got a FET+1 driver from MTN as well as a XP-L HI on Noctigon for which I measure 6.4A on start using a VCT5A. The S2+ got upgraded to a Triple-219C using also a FET+1 driver. Using an Efest Purple IMR I measure a current of 14.5A! Unfortunately, it gets hot very quickly, so I've programmed the turbo timer to 20s. I'm not really satisfied with the Carclo 10507 optics which should yield a narrow beam but is far to wide for my taste. Are there other options resulting in more narrow beams?
We're very glad to have you here, jdm!
Hi Joerg, welcome!
Can’t help much with the optics. I have an identical S2+ Triple and like the wide beam of the Carclo 10507. I also have a triple S2+ with this optic and XP-L HI U6 3A, here the beam is a bit narrower. I can’t see much difference in tint compared to the 219C Triple, but it gets less hot and has a bit more output.
Thanks! Hm, maybe I should switch to XP-L HI also? I’ve put a 1A in my C8. The tint of course is much cooler than the 219c but still OK for me.
I recently read something about Kathod or Ledil optics having narrower beams then 10507, but I guess they won't fit a S2+.
Welcome, try the X6 with a ledil Cute-3 RS or SS. The 20mm Carclo triples are too small relative to the die size to focus well.
Joerg, Welcome from a fellow flashaholic from the USA .
As I don’t own a X6, do they also fit to a Convoy M1 or C8?
Thanks @all for the warm welcome!
Welcome to BLF!
Welcome welcome!
It’s a 35mm optic so it’s too big for the M1 and too small for the C8. I mention the X6 because for any of them you will need a spacer and a few members can supply them for the X6. The Noctogon 32 fits this optic.
Ah ok, thanks. Yeah, I already got a spacer from kiriba-ru for my S2±Triple.
Willkommen, Jörg!
Switching the LEDs in your triple to dedomed XPG2 would make the beam more narrow and increase the throw significantly.
Welcome! Hope you enjoy!
Hi and welcome jdm.
Thanks, maxbe I should try this out.
In comparison to my triple 219C/S2+, if I would build the same triple again but using a bigger host, e.g. a X6, would this increase the possible run-time on turbo significantly until it gets too hot?
Welcom to BLF
Here is a beamshot of two triples :
approximately 1 meter from with wall @ around 6 amps.
X6 Cute-3-SS optic Nichia 219C D320 5000K (left) A6 Carclo 10507 optic XP-L HI V2 3D (right )
In my experience the greater mass in the X6 allows you to run it on turbo longer, and I like the beam profile from the larger Cute optics better.
This helps a lot, thanks. Given the XP-L HI has a narrower beam than my 219c using the 10507, there should be a considerable difference between 219c/10507 and XP-L HI/Cute-3-SS beams.
We’re very glad to have you here and welcome,jdm!
