I would like to know the actual gain in lumens and throw from one to the other, and whether the 519A is significantly “prettier” in terms of light quality than the XHP70.3 HI R9050.
30w vs 15w, you will notice a significant difference in lumen output. XHP70 in 9050 is way more green than the R70 variant
First of all it’s a larger LED which is more efficient at the same power. Second - it’s driven much harder, 5A at 6V means 30W of power, 5A at 3V means 15W od power. Yes, it’s significantly more powerful, we’re talking 3000 lumens vs. 1200 lumens. 519A can give significantly prettier light though because high CRI XHP70 is a lottery, you can get fairly nice tint below duv but also some ugly green meanwhile 519A is reliably good.
I cannot help with the first part of your post, but as for the quoted part, and in my experience and opinion, 519A has much better light quality than any XHP70.3 Hi in every instance I have personally seen.
I have never put a 519A either domed or not into a throwier light, from what I can remember.
As stated the 70.3 light would be twice as “powerful.” Higher throw with 70.3 Hi would likely be just from the raw output difference I feel.
I’ve had XHP70.3 Hi in both R70 and R9050 in lights like D1K, C8, M1, all with orange peel reflectors though. Pretty wide beam but does have decent reach. Usually if I have a 3535 or smaller emitter in that size light, it’ll be a smooth reflector for more throw.
I don’t use pencil-beam style throwers a lot most of the year. Really mostly during the Fall/Winter while hunting or walking around in the woods. I like to have a narrower beam when the woods are thick, because I feel a really floody light destroys your ability to see further than right in front of you,but they both have their uses
And what is the difference between the R70 and the R9050 in terms of light actually perceived by the user—is it significant?
I’d say it’s not, because of the tint lottery quite often R70 (which is more strictly tint binned so you can avoid ugly green) can look nicer to they eyes than R9050. It’s also brighter at around 4000 emitter lumens. It’s nice but of course it can’t beat high CRI Nichia when it comes to light quality.
My favourite CCT is 4000k, I’d take the R70 in a nice tint over a R9050 with green tint.
My M21H Has the R9050 in it which I regret slightly as it “feels” less bright than I had hoped for, and Simon has (had?) a batch of R70 with nice tint.
I have XHP50.3 R70 4000K from Convoy (5D tint which means at or below duv) and it’s lovely, Cree emitters seems to have good color saturation so even with low CRI colors look pretty rich.
But wouldn’t the fact that it’s the R9050 make the light look better in some respects compared to the R70?
Does anyone have a photo of the R9050 beam in 4000K?
Beamshot doesn’t matter because of tint lottery:
Pink dot - nice and neutral, yellow dot - ugly green. You’re equally likely to get either of them.
In my opinion, purchasing a light on high CRI values alone is overrated.
I’ve had some high CRI LEDs with green tints (maybe Samsung’s, or Luminous? I forget) and some low CRI (4000k XPL Hi) which look great.
Most people prefer neutral to negative Duv (ie. Very slightly pink/rosy hue). A handful prefer neutral to positive Duv (green hue).
Unless you’ve a specific LED you’re trying to replicate, I’d not over-analyse, and would go with the R70 given you want high output (else, why would you be choosing an XHP70 sized light…).
I’ll admit I’ve not paid close attention to all the new 7070 size LEDs that have been released recently, so it may be that you’ll find what your looking for from Luminous or Fireflies.
Thanks a lot for the input, everyone!
If you order the R70 and don’t like it, so long as it’s a fairly simple light (almost all of convoy range, for example), you could always swap the LED MCPCB, it’s generally quite straightforward.
In my experience
has been almost if not always above the BBL with R9050 Cree LEDs. I do have one single 5700K 70.3 Hi R9050 that isn’t too bad, but on lower levels it’s definitely green. Does not get rosy on high, only pretty neutral.
I’ve had a few very nice 4000K R70 XHP50.3 Hi and XHP70.3 Hi, they all came from KaiDomain or Convoy a few years ago. I don’t have any in a light currently, my only XHP light is a 5000K R70 D1K with pretty nice tint.
The best tinted high-CCT R70 emitter I had was the 6500K SFN60 from when Hank first offered them. Absolutely zero green anywhere in the ramp. Pure cool white, almost clinically sterile white, in the reflector D1K. Under the DM11 TIR it got green though. I thought I read that TIR optics usually lower DUV, but I’ve had the exact opposite happen with both the DM11 and D4S optics, either narrow or wide.
LH315D dog farts, I have 4000k and 2700k and both are super green
Edit: they both read great for CRI on my Opple, but holy crap are they above BBL
I’ve heard that the LHP73B and LHP 531 have beautiful colors; can anyone tell me if that’s true?
3000k and 4000k LHP emitters have a great tint, I absolutely love the 3000k W5050SQ5, great throw and useable spill even in a light like the S21E.
Here is the Opple reading on the 3000k LHP W5050SQ5
I love the 3000k 531 as well. Even though it is not hi cri, it is a great choice in my opinion. Lovely tint an no green to my eyes.
Do you think the W5050SQ5 would be a good fit for an S2+ or an S6?
