Hello all. I just posted in the TA Driver series asking for help and figured I should get all my questions out at once. I’ve built some S2+ triples recently and I noticed my tailcap amp pull is only 5.5A-6A on turbo. The drivers I’ve been using for these have been the MTN FET + 7135 Driver - MTN-17DDm, MTN FET Driver - 17mm, and 10+ Amp capable MOSFET 17mm LED driver. The cells I’m using are 30Q and VTC6 from Illumn. Is this normal? What can I do to get a full 3 amps to each of my LEDs? I’ve searched all over the site looking for this answer but no luck. I’m sure I just haven’t looked hard enough; any help would be appreciated.
What are you using to measure the amps? Thin wires on a DMM can really understate the amps.
Just a really cheap multimeter. The good one is in Indiana in storage. This is the multimeter I’m using: Cheap Amazon DMM
Try soldering thicker gauge wires to some plugs. I bet you’ll see a big jump in amps.
I didn’t really start getting acurate measurements until I bought a clamp meter—what LEDs are in the lights —- but mainly that meter is holding you back
A couple years ago we all got this meter around $30
I’ll probably break down and buy that. I see it on Newegg a little cheaper and figure I can wait for the shipping for the price difference.
@Pwsmith, as a starting point, you can just build a shunt using some wire or resistors.
Think of your flashlight as a closed circle in which the current flows from battery(pos) to battery(neg).
So the path of the current goes from battery (pos) through:
driver spring
driver board
driver circuitry
driver lead red
led board
led(s)
led board
driver lead black
flashlight body
switch
switch board
tail spring
and back into battery(neg).
The challenge is to minimise the resistance of each part in this circuit.
Springs usually can be bypassed. Leads can be swapped for thicker ones.
Not wanting to be disrespectful, but the DMM replaces the switch etc. in the tailcap by:
a sub-optimal combination of electronic parts and two very long, very thin, probes.
One probe on the “bottom” of the battery and one probe on the body of the flashlight.
Which add considerable resistance to the whole circuit. And as such choke the current.
Making it a measuring instrument that is compromising the measuring itself!
Replacing the old probes by short wires from electrical appliances + banana plugs will help a bit.
Buying a clamp meter will help a lot
Believe me, most of us have been there! ![]()
