Help a Noob again. M21b, what led for throw with not much hotspot
Hi friends,
That-guy-who-doesn’t-knows-his-leds again.
I currently own a T6, a C8 and I think it is time to get another great light from Simon, the well loved M21b.
I currently have a Wurkkos TS30s Pro and, while I like that flaslight quite a bit, I find the hotspot a little unpleasant when you are in the dark in an uneven terrain and have to point close to you. A little too bright.
So. Can you please recommend a good LED for the M21b that is nice and doesn’t has so much hotspot? Maybe they are all like that, as the led for the TS30 is pretty beefy, but I don’t know : )
I have been looking at some videos and the LHP73B looks pretty good in the photos and videos, but I don’t think I want such a photon cannon. Not right now…
I’m looking for 5000k. Any additional recommendation on what battery to get would also be appreciated, because I simply follow the rule ‘the more expensive the better’ otherwise.
Thanks everyone!
well get the LHP73B! you can run it on one of the 50% mode groups, or just never use the max outputs etc. if its the beam profile you want. and itll be more fun lmao. i think some of the Ampirus batteries, and the Eve like 50PL etc are great.
Battery: I always order the 50PL. Cheap, high-amp and with 5Ah enough capacity.
For the light - you could also go with the GT FC40 in 5000K, that will give you something very close to sunlight, really high quality stuff.
If you don’t want a hot rod, you could ask Simon if he can have the light built with an 8 or 10A driver? The lights get produced for each order anyway, so it’s no problem to put in a different driver, I guess.
I have a few M21B lights with LHP73B in them. 5000k is nice.
For a little less output and a smidge more throw, the LHP531 would also be a good option.
This 531 5000K in M1 (same reflector as M21B) and 20A buck driver
Hi everyone,
Thanks a lot for the inshights and the expertise.
I will still look some more but I wil likely pick a LHP531 5000k and a 50PL battery.
Oke of the photon-cannon-kame-hame-ha options is interesting, but maybe for another time : )
Thanks one more time to all.
