im a plumber/gas/pipe fitter by trade with an electronics degree. I mostly work on hvac systems, so I spend over half my day in the winter with my head inside furnaces and A/C units in the summer. as well as every other dark scary corner or crawl space imaginable……
right now I carry three lights to work at all times, a flooder, a thrower and one of my EDC lights…
ive been trying to find the one perfect light for my job, but cant find the one single one that has everything, maybe that’s a pipe dream but I want to keep on searching. I need something with a high lumens and great flood, but I also need a nice tight hot spot for locating cracks and trouble spots. it also has to be small with great run times……
I find the high output tube lights not bad, but get hot fast (I end up mouth holding a lot). I was thinking maybe trying the Zebralight SC600 out next, but not sure if it will do all I need….
any help would be greatly appreciated, unless im searching for the pink elephant that ill never find…
I need lots of light to light up my work area, but when I spot a crack way up inside a dark heat exchanger I need its focused on that spot to better examine it. or looking down a long dark crawlspace….
right now I usually carry a little tube flooder like my UF 2011, but it gets hot fast and not very focused, sometimes ill use my S20, don’t want to wreck it. ill also carry my convoy M2 or sometimes my nitecore EC25/EC2, for a more focused beam, but not to nice close up. then I always have my EDC with me like a S10(really like the magnet, perfect at work)…
it just hard with my job, on one call I could need three different types of light. so I guess im looking for the best all in one light 1 x 18650 size. was thinking bout the new zerbralight, but fear its only flood……
I do some HVAC work and cant live without my headlight! I have the dual led one like Fasttech carries Here
General lighting is usually taken care of by a chunky rechargeable dewalt light. Incandescent warm 100% cri goodness, not very focused fancy or pretty but the best option. I dont like flashlights in this trade Hands are generally a necessity. Its got the bendy neck so you can wrap it on a pipe or drape it over a rafter or something.
It you must have a pocket light, a sipik sk68/clone would be ideal as its small, bright and zooms for areas that you cant necessarily point the hotspot of a reflector at. My pops loves his zoomie headlamp I got him and hes an HVAC Tech.
I’m in HVAC also. I have a petzl headlamp in my toolbag for when I need it. Always have a Shiningbeam s-mini xml in my pocket when I’m at work. Both have held up great.
Something I put together for work on all things mechanical (all the way up to 200hp condenser water pumps)
A couple SC60w’s attached to 18” of locline…attached to a nice clamp with a rare earth magnet……I forgot where I put the pics, but
I get compliments all the time on the things…not cheap with an SC60 mind you but very very helpful.
I tossed them up on a unit and changed out a small blower motor and absolutely LOVED the amount of light I had coming from the left AND right…
I have a couple offers to buy them but I want $ up front…With a ZL they get very expensive…
I’ll look for the pic
Meanwhile I am working on a ZL600 version using 3/4” locline……
i’ll say the best one for you is UF-T20, bright enough for close work and also can zoom it for shining farther stuff
or you can use one of these headlamp
… it works wonder for me
hmm… this seller is in the US and sell it cheaper than what i paid… sheesh always the case
I have been using lights with a nice clip on my collar and roll the light under so it's like a light sitting on your shoulder ..i use the LD22 or a Hugsby p2 like that .I don;t like trying to hold a light in my teeth and a nice headlamp although somewhat awkward or geekish proves to be invaluable when you need it .A zebralight is hard to beat
I love researching and buying new lights but lately I haven't found ones that improve on my setup and I end up shelving the newer light in favour of the old one.
(These lights are a couple years old now and have newer equivalents)
Belt Holster: Foursevens Quark 123 Turbo X (Now the Quark QB2L-X)
Does most of the "heavy lifting". Spends a lot of it's time just on and lying in the blower compartment while I'm cleaning. My go to light when looking up from the blower compartment or searching for breaker panels, etc.
In the winter I should charge/swap the batteries once a week, in the summer I can get away with 2.
Light and easy to mouth hold when I dont want to reach for my headlamp. The small head makes it perfect for checking heat exchangers when the a-coil has ben placed too low (room to see past it through a normal step bit hole).
I follow the same weekly charging routine.
While this light was in my shirt pocket I never had a problem with it. I've changed jobs and dont have shirts with pockets any longer and now I'm finding my Preon mistakenly turned on very frequently.
Tool bag: Petzl Myo XP (Now the Myo RXP), Nitecore EA4W
I think the only way the Petzl could be more perfect for me is if the batteries just never died. The modes are well spaced and appropriate for close up control board work or late night searching for parts in the van. The flip up diffuser is a must have for any headlight I would look at in the future.
The Nitecore is a recent addition and really doesnt get much use as long as I remember to charge the others. I've found it to be most useful for looking into dimly lit spaces when the surrounding area is brightly lit (rooftop units) due to the high output and hotspot.
