Help choosing between Convoy S21G and S21B
If someone could advise the difference between the two? I’m looking for aluminum ones for better heat distribution . I understand both have 22mm drivers but I can’t really understand other differences besides the knurling design.
I’m mot looking for 90+ CRI emitter for this light, but best efficiency and sustainability, along with pleasant tint. So I decided to go with XHP50.3 HI R70 4000k which I’ve heard has pleasant tint and will offer higher lumens output and better efficiency/sustainability than 519a. Is it a good emitter choice for this host?
I’m aware of TIR lenses availability but saw Simon commenting that of TIR is installed the flashlight will not be waterproof anymore.
Thanks for stopping by, Teppka!
The S21G and S21B look pretty similar to me.
The difference might be mostly cosmetic, but I’m just guessing.
I noticed that the emitter selection is slightly different. :thinking:
EDIT1:
The XHP50.3 HI R70 is a great emitter, but it doesn’t throw very far (which may or may not be a problem.)
If you want more throw, I suggest ordering the light with an SFT40 emitter. :+1:
EDIT2:
You could ask your question in this thread and the owner of Convoy can probably answer your question.
https://www.reddit.com/r/flashlight/comments/1el6ajk/convoy_s21abg/
Seems to be very little difference indeed, pretty much just comes down to looks, I think.
