Hello everyone
I want to buy The conversion kit to convert my BLF GT to GT70 i know i should buy this The conversion kit
But i have some questions
1- Do i have to change the battery Carriers mine now is 16.8v 4 cells in series ?
if no
2- Does the Driver comes with the The conversion kit can tolerate 16.8 Volts ?
if yes
3- Does that mean this Driver is a direct drive ? or it is constant current driver ?
1. No need it for it.
2. The conversion kit does include the driver, and has no problem handling a max voltage of 16,8V, like the original BLF GT driver.
3. The TA driver used a MOSFET+resistor array driver, using SMD resistors as a semi-linear regulator at low power levels, with the MOSFET part of the driver kicking in at higher power levels of the scale.
So, no, it’s not a constant current driver. Doesn’t have any method of feedback to regulate the output.
