I wouldn’t buy a light I may need to use for extended periods of time that had a built in battery.
I want to be able to swap battery and keep using it.
Never owned a ZebraLight, simply because I see it as… I would rather have 2X Skilhunt H03’s for less money than one ZL .
BTW I do have 2X H03. Both NW version, one’s not stock any more, one is.
Only drawback of the H03 is that you need to turn the tailcap 1/4 turn to keep it from turning on while rolled up in the headband, while in your pocket. I use mine everyday and now it’s just muscle memory to lock it out or on with tailcap. I also require the magnetic tail in a utility light. The light arrives with magnet out, put it in if you want it.
