HELP find the right driver
can you please tell me which driver i must buy from FASTTECH for this T6 led torch because its own is broken!thank you!
http://postimg.org/image/6akjexcc5/
http://postimg.org/image/bqlk74ysf/
http://postimg.org/image/v2m196sfr/
http://postimg.org/image/j17nbvxwj/
hi, your looking for a 20mm two cell driver I think (measure the diameter of the driver or apperture it sits in).
not sure about fasttech but I would try to get this driver in there tbh.
I’ve used this driver a few times and it is a very nice driver in my experience.
Thanks a lot!
Use the existing driver as a contact plate by either desoldering everything off or my preferred option of taking a heatgun to it and flick off all the parts as it comes up to temperature.
This way you can use the cheap 17mm drivers like the Nanjg 105C.
you’d need a dummy cell to run a nanjg, that’s a two cell light.
oops! Didn't see that.
disregard my comment Manos778
its not a bad suggestion, just use a 65mm long 5/8 copper tube with two endcaps soldered on and sanded as necessary and your away.
