Just received a UF light from an on-line company in China but when i checked it out, the high mode is dimmer than the strobe and SOS mode. So I place a meter at the end of the light and the reading were:
strobe - 3.0 a
SOS - 3.0 a
high - 1.6 a
med - 0.7 a
low - 0.3 a
I had an HD2010 from TMart (strongly recommend AGAINST!) that had the same issue. A driver swap to a Fasttech 3A Nangj driver solved the issue for me too. It was an easy swap and I upgraded the emitter wire gauge at the same time.
If you also have an HD2010, check into whether the reflector is shorting out the emitter pads. I don’t have and HD2011 so I can’t speak on that one. I added two layers of Kapton tape to my reflector as an insulator. The stock centering ring was very poor quality and did not do a good job at both centering and keeping the reflector away from the base.
