I bought this Peng Wang light and it has a driver I’m not familiar with. Anybody have a clue?
I haven’t yet taken the light assist to see what’s on the inside. It’s not an H17F or H17Fx. If its a Convoy, it’s an older one.
The UI is 8 taps and then it starts doing 10 quick flashes. And tapping anywhere in those flashes just moves to the next mode group (of which there are four)
Probably not super helpful, but I think I can rule out all Convoy drivers because they have at most four 7135 chips on one side. I also remember Convoy’s old 7135 UI, and what you described isn’t it. Possible that it’s not a mainstream driver.
Probably something similar like this one… !?
H17FX driver
I don’t think it’s an H17F of any flavor. It doesn’t seem like it has any kind of FET channel. The SFT-40 is significantly underpowered.
Plus, all of the H17F(x) I’ve seen have a hexagon shaped outer contact ring. Where this one is round.
I don’t know, i simply trying to help around !
(And thats why i said " Probably something similar like this one !? ")
Looks like an old-timey 2.1A driver (7135s). No FETs.
I liked those better than the 2.8A drivers because going full turbo could make the light go untouchably hot way too fast, and the diff between 2.1A and 2.8A was visually negligible.
UI doesn’t jingle any bells.
No, I get it. And appreciate the input.
That would seem on par with what I’m seeing for output.
I’m going to take it apart later today and then post a pic of the back side of the driver.
Well… I guess it is a variation of an H17Fx.
It didn’t seem like it was the same UI. But, maybe I’m writing and need to investigate further.
