Hi guys.
First… I dont want to say where I purchased this intellicharger i4… I will only say if we conclude that it is fake/counterfeit…
I had a i2 from manafont since a year or two ago… It is legit because it has serial number both in the box and in the back of the charger….
but now I recently received a i4 and…… Just after opening the box I realized that something was wrong with that charger….
First… It arrived completely full of dust and debris… And the surface of the plastics arrived with markings as if someone mistreated it…. (My i2 arrived totally clean and with no marks on the surface of the plastic)….
Second. When I plugged and unplugged to the mains…. The leds didnt lit up as my i2 does… My i2 leds lit first the first one… Then it lits off and the second one lits on… And finally the second led lits off and lits on the third one. when unplugging the i2 it does the same.
But with this i4… When pluggin it to the mains… All leds lit on simultaneusly and instantly all leds go off.
And third and most important: IT HAS NOT SERIAL NUMBER NOR IN THE BOX NOR IN THE BACK OF THE CHARGER… (my i2 has serial number both in the back and in the box…. and they do match)
Is it genuine or a fake?
Ps: I read on fasttech that nitecore is no longer putting serial numbers on both the i2 and the i4… But I dont know if that applies only to the 2014 versions or also to the older ones…. (Mine IS NOT 2014 version because it has the blue mains plug instead of the yellow mains plug installed on 2014 versions)
any help? Thanks
