Hi BLFers I was wondering if one of you could help me source the switch gutts pictured below. Its a 3 position reverse clicky. Click once for HI, again for LO, once more for OFF. The LO mode has a current limiting resistor. The board is 20mm diameter.
Does anyone recognize this or a similar compatible design?... can you please post a DX or KD link?
That looks like an HS-801/HS-802 type of light? If you want to keep the two modes, I can't help. If you want to lose the low-mode and go to a single mode, these switches...
...would probably be compatible. I modded a Uniquefire HS-802 with this switch to remove the annoying 'low' mode successfully. The second choice would be to use one of these switches and to added a multi-mode driver if possible...
