help locating a low power driver for a 12V device
I need to power a 12V device at 100-350ma. It can probably run at 7-8A. I don’t think a zener can protect the MCU at that amperage. Figure 3 cells is 12.4V max and rated for 11.1V. Do you think I can run 3 cells on a 9V driver? I’m way out of my league here so any suggestions?
Well, it wouldn’t be very efficient, but the humble resistor would do it. I don’t know enough about zeners. Why wouldn’t it protect the MCU at that current?
I’m not all up to snuff on the board design, but attiny13a’s are rated for 5.5V max input.
Yeah, but voltage and current are two different things. Why won’t a zener do the job?
I realize that. MCU rated for 5.5V, I’d be putting 9-14V through the driver. Nothing to do with current. The Zener I believe steps it to 5.6v for the MCU, but what voltage are the Zeners rated to handle. Can they step down any voltage to the MCU? Do I need a different Zener? I know I will need a different resistor with the Zener. If I can make a Zener work, I’ll just use a single 7135 Zener modded board. I just want to know that there is a way to keep all of the voltage from damaging the MCU. Do I need to use the standard Zener we use and just change the resistor, or do I need a different Zener and resistor? Also, what resistor would I need?
Voltage regulator feeding a 7135
The way I understand it, the zener has a reverse breakdown voltage that it should keep the MCU pretty stable at. I don’t think you should have any issues, the zener mod kits at Mountain Electronics show that they’re good for 2-3S setups.
Use a zener diode and current limiting resistor, you’ll be fine.
