Some friends of mine are using infrared LED lights for injury healing, but these things are pricey! This one costs $185, but it’s basically a high-power infrared LED flashlight. http://www.tendlite.com/
With some help from BLF, I think I can make one of these. Here are the specs of the $185 device.
18650 battery
2600mw input
1500mw output
660nm infrared LED
Try mouser or digikey. LED Engin makes some high power 660nm emitters. LZ1-00R200 is 1000mA @ 2.5v. Higher than that philips luxeon but costs more.
Can you link to where anyone give an indication of the tendlite power? Quite honestly that thing looks like weak crap. Bit of googling shows its 3xAAA.
For a driver you can use a simple, cheap nanjg driver. A 660nm LED voltage is low compared to a li-ion (3v - 4.2v) so a nanjg driver could use some heatsinking to maintain the current.
agreed…it would be a little high, but as long as current was limited and there was good thermal management, the emitters should be able to handle it…the vF on the datasheet said 2.25 to 2.9 vdc so I think the 3.3vdc out of 7135’s would be ok…a wee bit high but alot better than direct drive
You could run a 7135 driver from a 3v CR123, I actually ran a 7135 driver at 2.8vin (NiMH pack) to a Amber XP-E before, worked great and no excess voltage for the 7135’s to burn off as heat. Could do the same with the LEDENGIN at 3vin.
700ma is the suggested max but with good heat-sinking and a DTP star, going to 1500ma shouldn’t be an issue, and the Vf issue would also be minimized through a standard NANJG driver.
…and you too can be pain free without your wallet being emptied.
Someone here can probably build a firmware for the 30 second timeout pretty easily.
edit: 1500mw is only about 670ma through the driver (2.25V at 666.67 amps is 1500mw), so a 2x NANJG 47-AK with a 7135 disabled will work perfectly. Leave the lens out of the flashlight and you have no lens losses either if you care for the unit like a medical device. http://www.mtnelectronics.com/index.php?route=product/product&path=67&product_id=240
you can easily add a 5W high power diode to accept a standard voltage drop between the 7135 output and the emitter.
They are small and will make up the difference for the lower Vf of the red emitters while still maintaining the current regulation.
You can always run this direct through two 7135’s because you don’t need modes for this light, right?
I have always been Under the assumption they were 2.2-6vin (which is why I even tried the idea and it definitely worked, led current was regulated at 700mA). Tho I could be wrong on the spec cause it’s just what I always assumed but don’t tell my running light that lol. It was in a starrylight SA-22 with 4AA’s in 2s2p for 2.4-2.8v.
Spec is 2.7-6v but there is no available data showing how accurate that is. The datasheet arbitrarily specs that I think, no graph is given to back it up and if there’s a description it doesn’t say much as I recall. It’s possible that the thing works fine at a lower voltage.
