Hi.
I already have few lights - Convoy C8+ XPL-HI, Convoy S2+ XPL-HI and FW3A XPL-HI.
I am thinking about buying another light for general use outdoors and indoors.
I find C8+ too throwy even for general outdoor use. FW3A is perfect indoors, but lacks throw outdoors. Convoy S2+ is set up with floody TIR optics and is used only indoors.
I have narrowed my search to Sofirn SP36 with Anduril and Emisar D4S with XPL-HI (dont want SST20 because of green tint on low power modes).
What do you suggest?
My observations:
D4S probably has better driver (3+FET?) so it means usable stabilized mode.
SP36 is high CRI, so its good for outdoors.
Probably longer runtimes on SP36.
4300lm for D4S and 5000+ lumens on SP36 - no big difference.
Throw should be similar too.
About 55$ for SP36 with sofirn batteries and about 75$ for D4S with battery.
I would also vote for the SPL36. It has a more usable Hi and Turbo mode because of its mass. It requires multiple cells,but it’s great that you can charge them all at one time inside the flashlight. Since you are getting it for both flood and throw, it’s bigger size should be less of an issue, as I am guessing you will be using it mostly outdoors.
True, but if you do buy the BLF edition, all of that isn’t necessary with the nice tint of the emitters (without the XPL2 green corona which the standard SP36 has) and the stock anduril firmware. :sunglasses:
They are both great lights but I find myself grabbing a Fireflies EO7 (XPL-Hi or Nichia 219B) for general indoor/outdoor use instead; the size and shape suits me, 21700 capacity is decent, and I don’t normally need much throw.
D4S, much smaller and lighter light which would make me much more willing/likely to carry it. I RARELY have the need for extended runtimes on high/turbo of the increased capacity of 3x18650. If I do need longer runtimes I just take an extra cell or two for my light…
DN35 and 70 are only “multi emitter” if you consider the XHP emitters a quad due to the quad-die design, but functionally they’re single emitter in a big reflector.
