dimension about 3.5mm x 3.5mm and pull it from automotive led
I had search some of cree product but did not find it
Thank You
Thank You
not everything is cree, try samsung, nichia, (LG?), osram, and there are a few others I cannot think of.
I’m not familiar with that one specifically.
Please try to provide a better (more sharp) picture.
If the corner of the die has a square cut out that reminds me of other OSRAM emitters.
I think it’s from OSRAM’s “OSLON Black Flat” line:
EDIT: Specifically, it seems to be the LUW H9QP (datasheet here).
I’m sorry, I’m new about LED thing :shy
Thank you Wight, that is it
anyway, what possibility to replace it with cree or other type emitter maybe ?
i measure it have about 1mm x 1mm die inside those Osram LED
Possibly (with a dedome), does it have room, it looks like those are reduced height for slim designs
Seems on par with a CREE XR-E
Interesting little LED for sure ![]()
Good find wight
It has the Oslon footprint, it does not fit exactly but I reflowed Oslons succesfully on XP-boards. A big issue for building into flashlights with a DTP copper board (which I use exclusively nowadays) though is that the thermal pad is not neutral but connected to the cathode (led+).
Thank you
mmm, dedoming part is PIT* ![]()
What do you mean “it does not fit exactly” ?
You are right, on original PCB those thermal pad is connected to Cathode too
more question
I just saw on datasheet, but it did not say anything about color temperature ?
because when i pulled them, still have 2 led survive (total 4 led)
test it, one is “bluish” than the other
Is this for an interior lighting application? What are you trying to achieve by replacing these LEDs?
This is headlamp for scooter
I want to replace the broken LED
Sourcing those Osram LED looks difficult
I have seen digikey/mouser and they did not have it
EDIT
Can you tell me Where you sourcing those Osram LED ?
Why not just place Cree on Cree MCPCB and use that? Djozz is indicating that while the Osram LED does not have the exact same footprint it is close enough to fit.
above this led have a reflector for aiming light to the road
I think positioning LED will be important, that why i’m looking for same dimension with the same emitter die area to keep beam pattern as close as possible
In that case I’d recommend sticking with the stock LED type. Substrate thickness may be different (it’s probably different) between the Cree LEDs and the OSRAM ones. Die size may be a little different. A dedomed Cree is just not going to be as durable as anyone would like for a headlight application.
yes i forgot about thickness :shy:
still googling where this thing is available ![]()
Actually, looking over the information again it seems that it could be either LUW H9QP or LUW HWQP. HWQP is the higher powered one I think.
…Both seem to be unavailable for purchase through component distributors.
I would contact OSRAM directly about purchasing / acquiring samples.
The LUW H9QP is available through rsonline.
Nice find djozz! I suppose tjeret should probably check the current being delivered to each emitter and see whether it’s OK to use that emitter. I don’t see any physical clues to help determine which emitter the stock one is.
Unfortunately if tjeret is interested in 100% safety / compliance with the original design, it could be difficult to decide based on current. Page 11 of both datasheets shows a derating line for each emitter. There could be some overlap: if the HWQP model is derated for 120°C to ~123°C it would be driven at only 1.2A, the maximum drive current for the H9QP. OTOH if the drive current is below 1.1A there’s a good chance that the original emitter may have been H9QP. I don’t think it’s possible to form a great guess even by checking drive current…
I can test the device if you want, i have bench supply (but sorry don’t have lux meter) ![]()
what current/voltage should i feed it to know the difference ?
Thank you very much ![]()
I recommend that you test the current provided by the driver used in the scooter!
at the board already have driver but the “funny” thing is this thing is voltage drive :~
using Thyristor and zener as reference
