Help me identify this cell
Hi guys!
My Braun electric shaver uses what appears to be a 14500 battery, and this battery is dying…
So I’d like to replace it. The problem is, I don’t know much about the stock battery, apart that it is a 14500 Sanyo, with markings L MFDL3 038804 (and, on the negative pole, something like 5 DW1, not sure about the W)
In fact the battery is quite like this one :
but with a purple ring instead of a light blue ring… from my knowledge of 18650 batteries, for Sanyo blue ring means 4,2V and purple ring 4,3/4,35V, am I right? I am not very sure about this…and there is plenty of other Sanyo batteries with white or black ring, so…
So, if I can transfer it to 14500, does it mean that my battery is a 4,3/4,35V 14500? I am not aware of the existence such batteries, but why not.
You could also tell me to charge the battery with the razor to check the end of charge voltage, but it is around 4,1V, and I am not sure if it is because of the charge circuit or because of the battery…
Could you help me identify the battery? I’d like to keep the practical built-in charge function (you have to disassemble the razor to put the battery apart) with a new battery, but I don’t want it to explode or whatever :smiley:
For 18650 that means capacity, and I’m 99.9 percent sure that for 14500 the ring also means capacity meaning you can use any 14500.
You can fully charge it and use a multimeter on it, losing capacity doesn’t mean charging to lower voltage, it means it will drain faster to empty voltage
That’s good news :slight_smile:
My English is far from good, I meant the battery “fully” charged by the razor is around 4,1V, and I’m not sure it is because of the charging system (which does not do a full charge, which would be strange), or because the battery has so much self discharge or whatever that it is not able to hold 4,2V (or more) :wink:
Actually the main problem of the current battery, besides the very low battery life, is the voltage sag like you say, the motor or the charger does not have any “strengh” anymore, so it doesn’t shave well hard hairs :smiley:
That`s normal. I charge batteries with Nitecore i4 all the time and it leaves them just a tad below 4,2V. Always better that way than overcharging witch kills batteries quickly.
Sounds like the battery had lost it´s capacity.
Some devices charge to 90% or so so you will get more cycles from the battery, or it could be an out of spec charger. Either way if you did toss a 4.35V battery in it you would be doing no harm. You can use a 4.3 or 4.35 battery in a 4.2v setup, your just under utilizing it, but you can’t put a 4.2v battery in a 4.3/4.35 device without negative consequences
You can wire in a fully charged 18650 if you have one to see if it works properly again before investing in a new battery, high voltage sag would come from the high internal resistance of an old battery.
I have a 840mAh Sanyo 4,2V ready to be filled in :smiley: The razor works fine with it.
My problem is, IF the setup is using 4,35V battery/4,35V charger, putting a 4,2V battery inside wouldn’t be a good idea, as you say.
I’m well aware some manufacturer only charge batteries to 4,1V (90% or so) to maximize battery life, and considering the very limited autonomy claimed by the manufacturer (45 min), maybe that’s what they did…but I’m not sure…and if I were them, I wouldn’t have, because 45 min is not that much, and less than the previous generation of this razor (which used 2 AA NiMh batteries), but who knows?
I should find a way to measure the battery voltage while charging, but it will be difficult |(
And do 4,35V 14500 exists?
Edit: also does the code on my current battery tell you something?
I’m not aware of sanyo making any 4.3 or 4.35v batteries but use goggle to find more details on that battery
I did, found nothing interesting :frowning:
e-mail sanyo :wink:
Ok, will do, but I don’t expect any answer from them. A few years ago I contacted them regarding some NiMh batteries, and I never got an answer.
What is the model number of the razor?
It is a Braun 570. I tried searching for “Braun 570 battery” but results are disappointing at best.
I think I’m going to pull a Zebralight 14500 protected battery, and see how it turns out, protection should help 0:)
e-mail some of those companies that rebadge sanyo cells or sell 14500 sanyos
Are you sure it’s lithium? Here is what I found: http://hqrp.com/hqrp-battery-for-braun-540-570-3510-3511-3512-3520-5417-5427-5443-5444-5446-5510-2500-2501-2505-2514-razor-shaver.html
Yes I’m sure, it’s written on it :smiley: And also 4,05V right now :slight_smile:
That’s why I said researches lead to disappointing results. Maybe other series had NiMh, I had a Braun 5000 something that had NiMh.
Edit: could try to contact Keeppower for example, why not
That is all I could find on that specific razor. If it was mine and I was serious about replacing the battery, I would contact Braun customer/tech support for a definitive answer. Better safe than sorry. Good luck.
In fact a few months ago I did get in touch with a local Braun after-sale service support, they told me I’ll have to send my razor somewhere, and it will cost me around 50€, so…
I think your over thinking this, just get a 4.2V 14500 cell, install it and your all set
You convinced me…I think.
I wanted to put a protected 14500, but of course it doesn’t fit. So unprotected Sanyo 840mAh it will be…we’ll see, thanks for the help :slight_smile:
Yep. Just go for it. If Braun wants that much money to fix it then a little experimentation is in order. Worst case scenario? You get to buy a shiny new razor.
