This is a tailcap from Xiaozhi (bought at FancyFlashlights), the switch PCB board is not centered and it’s upper left corner is UP by the height of the brass ring.
The brass ring is stuck in there due to the amount of friction and just won’t unscrew
The rubber boot was teared a bit and is stuck just on that side where the board is lifted. I teared the rubber boot off since I want to replace it with lower one.
I’ve desoldered the spring for easier access and overview.
The aluminum ring on the boot side can be moved around with a screw driver, it’s not easy but possible and doesn’t help a bit.
Options I see:
destroy the PCB with a drill bit and hopefully save the ring and switch
destroy PCB and a switch
drill bigger holes in the brass ring and try to unscrew it somehow without destroying anything
heat the whole thing up and hope for the best that it will unscrew (should make less friction with the tailcap aluminum body)
hammer the PCB down below the ring on that one side somehow, but I don’t think that is potentially helpful
Tools I have a drill and a small drill for precision work, can drill small holes 1mm / 1/25th inch minimum.
It’s not a problem to hold the tailcap or to keep the tool in the holes, the problem is that every tool I use to unscrew it bends.
And yes I’m unscrewing it counterclockwise and the thread is counterclockwise to unscrew.
Now, where can I get this switch? Or just a nice gold plated pcb for a switch?
Or the 20mm brass ring?
How is the switch attached to the PCB? Anybody has a close up picture? Can I even get the PCB out, drill it, dremel it away?
Any tool I could use to unscrew it? Hopefully with two very strong tips.
Heat the tail cap with a torch. Do not heat too long. Just get it hot to where you can't touch it. Heat all the way around and then use needle nosed pliers or snap ring pliers to turn the ring out. Also you can use some WD-40 on the threads, but the thing is probably glued in, so heat should do it.
As far as the rest, the switch is soldered to the PCB. When you take it out, you can replace the rubber cap and put it together and try to center it a little better. Once you have it apart, you will see it better.
The head wasn’t glued in. Is that a common practice?
Ok I’ll have to search more tools, since needle nose pliers are too big, I doubt we have smaller ones. Maybe somewhere hidden might be the snap ring pliers but I haven’t seen them for years.
What could I use to heat it up and not destroy the plastic switch? No torch around.
