Help needed, killing emitters in new mod.
Fellow modders,
I need some help with a new build which seems to be killing emitters. The basic set up is a quad XM-L2 maglite driven by 2S lithium ion. The driver is a BLF17DD-Z. with the following components.
R1=200ohm
R2=4.7k
R3=19K
R4=10ohm
C1=Cap
D1=zener
The components, emitters, and firmware are from/by RMM, so top shelf stuff. The firmware is 3 mode with N-lite/star type options and the driver works fine.
The emitters are wired 2S2P.
I lost three out of four emitters due to a reflector short on my first try. I rewired using three new emitters and low profile copper strips and promptly blew the fourth emitter that hadn't gone the first time. I figured it had been weakened by the short and replaced it. Put the light back together and tried on some worn out laptop pulls. No problem at 3.5 amps at the tail. Tried on a pair of good tool pack pulls at 8 amps and blew another emitter. It wasn't a short as the copper was well away from the reflectors and covered with Kapton tape. There is no electrical continuity between the wiring and the heatsink/noctigons. I'm getting around 8 amps max at the tail so I figure each emitter gets about 4 amps. The light is very bright while it lasts. There is no blue color shift before death and it happens very suddenly, killing only one of the 2 emitters in the series. After killing 5 emitters I'm about to call it quits and just go with a single MT-G2!
Anybody got a suggestion?
Brian
The newer XML2 cannot take the same current as older stock.
My guess is you have a pair with mismatched Vf, one is getting more than 4 amps and blowing.
bdiddle could be right.
I’m not thinking 100% clearly at the moment, but I think a legit suggestion is to join the two parallel chains in the middle. This should help minimize the damage done by Vf variation. EDIT: in other words your XsXp setup should look like a ladder, not two parallel pipes.
Also consider using XP-L instead, it sounds as if the best binned 2x2mm chips may be going into XP-L right now.
Agree with wright. I would also get rid of the copper and go with wires, probably 22ga, just to have some resistance and make sure all the wires are the same exact length. Too much current and imbalance. Even with modern leds, I still don't do them parallel that way.
Wight,
Are you suggesting adding connections physically in parallel to the longer copper strips but on the inside close to the wires?
Brian
Pretty sure that’s not what I’m suggesting. Sounds like you are suggesting something very bad, if I interpret you correctly. I can’t draw you a picture right now.
Here’s what you’ve got:
L
7
Here’s what you should do instead:
L
H
7
This is still 2s2p but now you’ve got taps in the middle of each 2s which connect. Simple.
Think of it as putting a pair of emitters in parallel. Finish up your wiring. Now put another pair of emitters in parallel. Finish up your wiring. Now place both parallel pairs in series.
Wight,
I don't get your notation, to tech for me? Is the below what you are suggesting?
No, you have drawn a dead short. :frowning:
EDIT: I have edited my post above with the ASCII art you found confusing. The forum changed the formatting. Hopefully now you’ll find it more useful. It is simply a visual representation of two different ways to wire 2s2p: without the ‘ladder rung’ and with it.
Hmm, go back to your original photo of the LED’s. Those 2 copper straps on the outside: put a jumper connecting them together.
I'll try that tonight, thanks guys. EDIT: Maybe I'll figure out Wight's art by then...
Aww :frowning: I’m so misunderstood!
I altered the wiring as suggested by Wight and as explained by LowLumen and it worked. While I think there was indeed a vF imbalance there is also the possibility that a solder spur was shorting on the reflector through the Kapton tape. The light now fires on all four and is stupid bright. Thanks again folks.
The solder spur makes way more sense. I’ve had that problem.
Glad you got this thing up and running!
What reflectors are you using?
Convoy series S2 reflectors.
