Help needed with Anduril V2 setting momentary moon brightness level
Hello.
I set fine my light but every time I try to adjust the ramp config menu the momentary moon (when torch is blocked)light much powerfull than default.
After put the ramp config mode to original values the momentary moonlight(and momentary low too)
Ho coul get the original momemtary moonlight level? Is it possible to disable this function to avoid involontary battery drainage?
Sorry for my eng
Rergards
Lockout mode also doubles as a momentary moon mode, so the user can do
quick tasks without having to unlock the light.  The brightness in
lockout mode has two levels:
  - 1H: Light up at the lowest floor level.
  - 2H: Light up at the highest floor level.
        (or the manual mem level, if there is one)
Hi.
Yes what I meant is that after ramp config 1H and 2H are (both)significally brighter. If I want to get the original moonlight brightness i have to do a reset of andurill setting loosing all the rest.
Why that happens?
And what about disable this function?
Perhaps change the title of the thread to “Help needed with Anduril V2 setting momentary moon levels”
Done! Thx
Then lower your floor config in the ramp configuration menu as described in the manual: http://toykeeper.net/torches/fsm/anduril2/anduril-manual.txt
Sorry but I’m still missing the point.
If you change the floor levels, that’ll then change the moonlight in lockout. You can’t alter the floor and also change the lockout brightness to something else
the floor of stepped ramp, and
the floor of smooth ramp,
are used for the 1H and 2H outputs, when locked out
