Lmao.
Btw, cold doesn’t crack glass, it’s fast temperature changes that will. When part of the glass is hotter or colder than another part is when it cracks.
You’re risking kinking the bezel and will never generate any significant torque that way. Following the great advice from TomE ( a very successful and meticulous modder who tore down almost every light he owned), I bought a pair of Boa Constrictor aluminum strap wrenches. They have nylon cords going through the straps and can withstand a lot of abuse. Amazon.com
Ive destroyed all my other strap wrenches and these are the only ones to have held up through years of extreme abuse. They are an investment, but will quickly pay for themselves after you’ve damaged your first expensive light trying to crack it open.
As long at the lens is made of glass and the reflector is aluminum, you can use a propane torch to heat the bezel to a higher temp more quickly than a heat gun. Repeat and let cool several times to soften most glues. Then the Boa’s will do the rest. Apply even heat to only the outside of the bezel and keep rotating the light until a slight burning smell is detected. Then let it cool. Its far better to be cautious and heat cycle the bezel several times than to get aggressive with the heat.
For the most stubborn lights, while the light is still very warm, quickly wrap it in high quality duct tape at least 3 wraps, then immediately try again with the Boa’s. Do this in a warm environment to minimize heat loss (I wait for the hottest summer days). Have the tape pieces cut to size (one for the bezel, one for the light) and ready to wrap. Have your Boa’s laid out and adjusted in the correct directions to grab and apply torque for counter rotation. If you break it lose, you might have to swap from clockwise, to counterclockwise rotation several times to prevent the threads from galling and becoming damaged… similar to tapping threads in hard metal. You might have to reheat several times as you go through this process. A high quality duct tape will withstand the higher temperatures without the adhesive separating and becoming stuck to the light, and it can often be reused several times between heat cycles. I have yet to find any actual benefit of freezing a light, and I have tired with several. There is a learning curve as you figure out what works best for you. So dont get discouraged if you dont first succeed. It took me a while to become proficient with the Boa’s and find the best way to use my body to apply maximum leverage and torque to both wrenches at once. Straddling a wooden bench while using a thick cotton towel rolled up into a tight roll, has worked wonders in proving a stable working platform.
Some lights have taxed the very limits of my strength and endurance (100+ ft pounds of torque)… so if they imploded, oh well. I didnt like them the way they were before modding so might as well do or die. Now I try to research what it takes to mod before I buy, but that isnt always the case. lol
Good luck!
BTW, is that your T/A? 78’? Super cool car! I built a SD455 for a friend with a 70’ T/A. Put down 791 RWHP 840 ft lbs torque on the chassis dyno during a hot day. Stage 4 Pontiac nascar ported heads with matching medium riser duel quads Pontiac used for development. Beyond the engine, I was always amazed how well it handled for an old large 2 door of its day.
That’s a lot of awesome useful info! Thanks! I’ll definitely keep going. This light has been stale on my shelf for a long time now. Gotta give it new life.
Just a question, won’t the torch damage the anodizing?
Yes! 78…
Wow 791 whp is crazy! Mine is nothing out of the extraordinary… stock 400 with long tube headers, performer RPM intake and edelbrock four barrel.
Never dyno it, but my guess it around 300 crank… 320 maximum.
But it breaks some necks for sure. Especially in my country that nobody knows what it is.
I have never discolored the ano before but others have. If that happens, you can bake it in an oven to turn it orange or strip and polish it. Lots of info in how-to threads on BLF if you search.
Well darn, Im jealous now! I didnt realize you were in São Paulo, so you must drop a lot of jaws cruising the streets. I only get that in my 70 XKE in the US. Yup, you still have plenty of horses and torque for fun. Did you import it or buy locally?
My dad helped me import it back in ‘08… the most bureaucratic pain in the butt thing ever. But it was worth it. He also brought a 78 25th anniversary edition stingray… been his baby ever since lol.
The XKE is the e-type is it not?? If yes that is one of the most beautiful cars ever made.
Thats a very nice garage. Love the tile floor. Im so glad you were able to cut through the red tape and bring those toys into Brazil. Do you have a shaker scoop for your TA?
My brother in law owned a 78 L82 pace car several years ago. Same car as your Dads with a few more HP and paint. Fun, fun car. You guys got it going on!
Yeah, E-type convertible. Im surprised how many people have never seen one and think its a one-off.
Good call on Boa Strap Wrenches! They’re definitely worth purchasing and inexpensive as far as tool investments go.
Duct Tape whose adhesive layer won’t separate or leave its residue when heated would be great!
I would sure appreciate having you recommend the brand you use. Thanks!
The car actually came with it in the trunk and we never been able to get it to fit. Tried a few times but my guess at the time was that the air filter being aftermarket didn’t allow it to secure it properly. Also the intake is a bit taller as well and it was pressing the thing against the hood.
Gave up many years ago and just got used to it. Now it’s a shaker filter instead.
Had plans to buy the bird decal as well. That was another thing we gave up on it almost a decade ago.
Yeah they seem so much nicer than the plastic ones I have. Now I have to figure it out where to buy them in Brazil.
Im eternally grateful to TomE for sharing that tip with me. Ive used Boa’s on everything from cars, to planes to antique lanterns.
Looks like the tape Ive been using is “3M 8979 Performance Plus Duct Tape”
Even when I searched here in the U.S., I still had to order online through Home Depot. So Amazon.com is likely your best option.
Thanks so much FP! I’ll be ordering a roll soon.
Is your intake manifold stock? If you ever need someone to relay ship, let me know and I’ll see if I can help out.
If you’re determined, you might save your original shaker and order a reproduction top scoop to modify to fit. IMO, they look really sharp and finish the classic TA look. Same with the decal if I can help out. I checked for someone else around 5 years ago and someone was reproducing them in 3M film, cut to order so no old adhesive to dry out.
Glad to help!
It’s a edelbrock performer RPM intake. Don’t know the exact height but I’ve told they are about a couple inches taller than stock. Air filter actually sticks out the hood.
Would be nice to have it fit under the shaker. Maybe someday! But I really appreciate the gesture. Perhaps someday I’ll take you up on it! lol
