This went well.. took my Streamlight ProTac HL USB head light and swapped out its LED with a Convoy LMP LHP531.. tho i cant get to driver, the 531 does great at what ever its output is. Supposedly 1000lm, do no idea as to what it is now but will test it out better tonight.. nice and wide beam and 6500k.
It has a funky battery configuration, this is it out of the wrapping, can still use a std 18650 but you cant charge it via on-board port, to bad streamlight cant get fully into type-c charge port like dang near everyone else, charge circuit built in ..
Oh man the C8 with the SFT-25R is an awesome combo..
This little light is a top of the list in my still small collection, now i need a new C8 host to make home to a LMP LHP73B and a OP reflector im getting soon.
Should i go with a 20 amp that its listed for ? Or is that a bit much for in a C8 ?
Also need another one to do a colored thrower, i have a super cheap FastFire C8 that has a red led in it, but it has a pressed in led star back board, nothing behind it, great for the low power it has now but definitely wouldn’t want to use more power in it right now
It’s a bit unclear to me what you want out of a C8 LHP73B–it’s a somewhat awkward combination. It’s not gonna throw well due to battery drain and overheat, doesn’t sustain flood for the same reasons, and is too big to be a compact hotrod.
If you want to experience the LHP73B emitter, do a compact hotrod like M21B or a larger light like L21A (good thermals).
If you’re looking for throw/flood balance, the F150R is a much better choice, throwing somewhat decently even on a lower setting.
The C8 with the SFT-25R is now my favorite as in a small thrower. Beings i realy like the size i was thinking of the bigger emitter, and yeah i know the deep reflector wont be the best choice for a flood light.. ive also just got a S21A, not sure yet but was thinking of doing a SFT-60 and a 10 amp. Would like to have alot of light for upto 75 yards
Got the L21A that has a SFT-60 and 15 amp combo, almost a swell general purpose light.
So now i just want a couple of flood/general purpose lights.
That and a red or green general purpose lights.
I just put a LHP531 in a headlamp and for its purpose is great.. was thinking that type of led would work great in a bigger host, more for wildlife viewing..
Sorry if im not making sense, sounds right in my head, but man, they got me on 7.5/325 percocet and 10mg of Flexeril, so may actually not making sense.
Wanted to keep it not any bigger than my L21A but bigger than a S series.. color lights can use a 18650 size as it wont be on alot, a white flood light would be used more.. so a 21700 would be best in a larger L21A..
I see! If you’re ok with the size then M21A is a better option than the C8, having almost double the battery capacity. M21B is slightly more compact and floody, also a great option.
I moved most all of my lights to the LMP LHP531, S21A, S2+, C8 and the L21A got the LHP73B at 15 amps. I think this will be what i keep them at after testing others..
The first light in this thread is about to get what i hope is an upgrade.
Has a SFT-25R and 8 amp driver.
I got a brand new and a lightly used 15 amp if someone wanted to trade for a 20 amp…
Got a few Green led tail switches also..
Might be putting some of this in the for sale section here shortly as im finally got most all of my lights sorted out, just waiting on my Red led C8 to replace a cheap Vastfire unit..
To manage expectations, I don’t think this is an upgrade in terms of output, if you already have a new-batch SFT25R 5000K. The W5050SQ5 has lower output/throw than the new SFT25R and much higher Vf, so it’s likely that the emitter won’t be able to draw the 10A the driver permits.
If you have a years-old SFT25R, it would be an upgrade.
Ahh. I was hoping it having a bigger 5050 vs 3535 size it would handle more amps/heat and (hopefully more output)… i take it not all adds up to a bit more output..
And yes its a newer 6500k from just a few months ago but no telling when it actually was made..
That was exactly my hope too when I ordered it, so I was disappointed to see it underperform the SFT25R. It still has a place though, being the throwiest sub-4000K emitter available.
I’m actually not sure if the 6500K also received the 5000K’s upgrade. I guess you’ll find out!
Well in that Cyclops light, ive tested up and with its deep reflector and the SFT-25R with 8 amp buck driver does a great job for its purpose, is an upgrade to what it had, ill stick with its combo unless i just wanted to try a 10 amp driver just to see if it burns it out or now..
Lights from Convoy so far.
T2 with 1.5 amp driver, SFT-25R and OP reflector.
S2+ with 8 amp driver, LHP531 and OP reflector.
S21A with 10 amp driver, LHP531 and OP reflector.
C8 with 8 amp driver, LHP531 and Smooth reflector.
C8 with 2.5 amp driver, SST-20 DR and Smooth reflector.
L21A with 15 amp driver, LHP73B and Smooth reflector.
