HELP!! Replacement SR STL-V2 lens needed!
I just broke my SR STL-V2 lens yesterday and need a replacement.
Size is 58-59 mm in diameter.
I can't find it anywhere at the usual Chinese sites.
Flashlightlens.com has an acrylic one that will fit, but I prefer glass.
If anyone has a spare lying around, I would GREATLY appreciate it!!
Hi Hill, I have the same problem with a broken lens.
Have you found a solution?
No I did not. However, I did order a Small Sun ZY-T13 and used the glass lens from that (they are the same size).
As for the ZY-T13, I had a crappy plastic lens lying around for that.
The biggest lens I have found is 55mm at DX.
As far I know, STLs, HD2010, ZY-13 & 18 use the same 58mm lens and no Chinese vendor offer this size.
Why don’t you try it from a salvage store. On the other hand, you can also try to find it online. There are many vendors operating online on such items.
Any updates on this? Searching for such a lense too!
got mine here, under 59mmx2.25mm but not cheap.
Thank you! But that is really expensive…
Half the price of a new light :S
