The other day I was playing with my Solarforce L2i when it had its last ‘click’. The tail switch no longer works. No clicks, no mode changing… nothing.
I emailed SF-sales and they told me they have no replacement parts and basically that I am out of luck. Can anyone instruct me on fixing it, as I don’t have the parts to do it.
Or can someone do the repair for me? This isn’t a light I necessarily want to have rendered useless as it is basically a collector now.
Yeah, that should be fixable. First take a pair a tweezers and insert them into the holes in the metal ring on the inside of the switch. Unscrew that piece. Then measure the diameter of the board that is in there, based on that I will give you a link to the correct switch.
I had the same problem with one of my L2i-s, somehow the clicky was fried when I used some bad P60 module (I think it was shorted while using an 18650 battery, not sure).
I bought these switches: http://dx.com/p/clicky-switch-for-flashlights-11-8mm-5-pack-5604, and for some reason I forget now I replaced the internals of the switch rather than replacing it altogether. Maybe the legs didn’t fit? dunno. Actually, I think all I needed was just to replace the button that somehow melted a little and slipped rather than applied pressure on the mechanism inside the switch. A word of warning if you choose to open the switch - the spring is very small and very springy… (and for some reason I suddenly remember two springs)
I was just looking for a switch myself. Tail switch on my Darth died. Blackshadow sent a whole battery housing and that switch died too. They said to send it back and they’d repair. But seems like a lot of hassle.
I’ll have to check the size and scope out the links. Thanks!
