Should be possible, there’s nothing on the battery contact board. 2 wires and you’re good.
Though if you look inside the driver cavity you’ll see that flat part on the switch side, it constrains the “diameter” to ~14.5mm. Some 15mm driver may require some file work to fit.
Well not without a buck driver, and I’m not sure how well the existing ones (in 15mm??) regulate with 1 cell + a 3V LED. And then there’s the space constraints, with finding such a driver that physically fits.
1 OR 2 cell buck-boost to 6V (in a small & neat package) doesn’t exist at all, I think.
The original driver will work with 1 or 2 AA / 1x14500, but I’m pretty sure 2*14500 will kill it. And it had some serious downside but I can’t remember what that was. Low frequency PWM?
The stock reflector opening is ~1mm too small for 5050 LEDs, but that can be reamed to size.
No idea about the XHP stuff though. The beefiest thing I own is a Luxeon V.
Make up your mind if you want to keep it somewhat throwy or not, and I’m also not up-to-date on 14500s - if 3A or even 5A is a reasonable limit for those cells, does an XHP triple even make sense?
