Thanks for confirming that on the board. I will probably need some help later on to make the piggyback work correctly (wire connections and so on… :person_facepalming: )
Hum, I guess that even a double-sided populated 15mm driver will fit with few issues. Still, if it doesn’t, I may file a bit the driver or the inners of the head! That will probably be the easiest thing to do :smiley:
Oh man…there goes my initial idea for a super light :person_facepalming:
I will have to analyze then what will be the best configuration taking into account the available drivers, above all, and Leds. I don’t mind using it with only 1 cell, but with 2 would be awesome… But all the drivers for it are huge :zipper_mouth_face:
BTW, that may also compromise a future mod I intended to do on the Tool25 I have on its way… Oh well :person_facepalming:
The original driver didn’t have visible or non visible PWM. I took some photos when I did the review and nothing as noticeable.
I just didn’t like the ramping it has :weary:
The cells wouldn’t be a big problem, as the Efest purple, Windyfire and the new Vapcell 14500s are good cells on relatively high A. Not much capacity, anyways, but high drain enough for short bursts.
My biggest issue now (besides piggybacking) seems to be the match of driver/emitter/2 cells.
Thanks for the help so far. :+1:
