Help with 26650
I need some 26650s and I am not sure what to get. I found these http://www.efestbattery.com/index.php?route=product/product&keyword=26650&category_id=0&product_id=55
And also these http://www.efestbattery.com/index.php?route=product/product&keyword=26650&category_id=0&product_id=954
What is the difference between them other than the price? Also what 26650s would you guys suggest? Thanks!
Anyone have any suggestions or comments? I know there are at least a couple battery gurus in here :bigsmile:
I'd go with the Trustfire Flame Protected 26650's from FastTech (not the black and silver version). Note that these are protected even though the drop down selection box doesn't say - just look down in the specs section.
-Garry
One has a higher capacity, 3500 mah. These are high discharge lmr cells, make sure that’s what you need…what are you using them in?
I would go for the King Kongs at FT. I just purchased some recently and they are working great. The flat top is not protected. The button top probably isn’t either.
http://www.fasttech.com/search?king%20kong
i vote for kingkongs too :slight_smile:
depending on where you live, the Enerpower 26650’s have tested to be the best by HJK.
too bad there isn’t any decent sources in the US.
Also I have Keeppower 26650’s which work great for me except for the fact they are too long for a few lights, being 70.5mm.
I am going to be using them in the ElektroLuens Bruisers. They need to be able to handle 10amp discharge. Thanks for all of the suggestions.
